fullnoise wrote:There is a turbo Polar Sliver Oval in England though.
CYA, CT
Amen
1956 - type 1 oval – mark thurston (aka fluff walker)
engine \ ignition \ transmission
type 4 2466cc (74x103)
2.0 litre conrods – balanced and checked for straightness - with raceware bolts
74mm counterweighted crank
103mm j&e barrels & pistons
berg 3/8” chromoly pushrods
european racing reworked heads with siamese valve seats, welded & ported
raceware aircraft spec case bolts and head studs
webcam turbo grind cam
remelle bolt on rocker covers (o-ringed)
dta fuel injection management with jenvey throttle bodies
garratt t 3-5 turbo with stainless header
race products water charge cooler
erl water-alcohol injection
taylor machine billet deep sump
13 row mocal oil cooler (for interior heat)
19 row mocal oil cooler and 9” pacet electric fan
porsche 3.2 carrera (911) g50 5-speed gearbox (good for 600bhp)
uprated irs driveshafts and cv joints
hydraulic operated 3500lb clutch and one-off flywheel
thurston fabricated gear shifter and linkage
wheels \ suspension \ brakes
porsche 7x17” turbo 4 cup alloys with yokohama a520 tyres
framehead raised 20mm
cb dropped spindles
front beam fitted with sway-away adjusters and narrowed 40mm
front porsche 944 aluminium hubs and vented discs (11”) with brembo 4-pot calipers
22mm front anti-roll bar
rear sway-away 25mm torsion bars
porsche 944 height adjustable training arms
rear porsche 944 discs (11”) with 4-pot aluminium calipers
18mm anti-roll bar
linelock
body \ interior
special mix paint based on polar silver
autometer street tach
autometer oil temp, oil pressure, boost guages
simpson 4 point race harnesses
porsche 911 front seats
interior trimmed in green leather (tony archer)
but its not a scratch on this beasty that will be out this year in the VWDRC
1952 – type 1 split – martin taylor (aka blue harrison)
2853cc
autocraft case
autocraft heads, water jacketed for additional cooling
high power NOS
dta fuel injection system with 44mm Jenvey throttle bodies
autocraft gearbox, quafe diff, berg 5 speed conversion
centre line wheels using 135 front tyres and 10.5” houser quick time rear tyres
3” narrowed front beam, with berg adjusters
neal front disk brake kit
tube chassis over the top of a 66 pan (retains functionality of a full pan car)
rear location bars are custom made and locate from the middle of the car to aid weight transfer
rear brakes use willwood disks with ford cosworth rear callipers inc hand break mechanism
rear avo coilovers, 450 lb springs
body \ interior
rear fenders raised 2.5” up the body to clear rear tyres
removable rear wings using quarter turn fasteners
fenders are the original 1952 items
beird bucket seats, modified to fit in-between the tubes of the cage
wool headlining and the rest is trimmed in leather and cloth
custom steering column
autometer monster tach with shift light
autometer oil pressure, oil temp, head temp (pair), brake pressure & voltmeter gauges
multi-point roll cage
holy mumma!
