removing sliding door trim????
https://forums.aussieveedubbers.com/threads/16153/removing-sliding-door-trim
kombi_kid ·
hey
im referring to the bit of beltline that covers the sliding door track.
these things are a bitch too get off anyone got any good ideas?? i have removed the 3 screws etc?
rhys
Andy ·
LOOK IN THE MANUAL. It’s hard to explain but there is a rod that runs the length of the cover which need to be moved ~1” forward before it comes off. The put a soft bit of wood on the bottom edge an tap it up to remove.
The opposite side (non sliding door side) doesn’t have the rod, just the 3 screws (some only had 2). Again a bit of wood and tap it up.
:thumb
kombi_kid ·
yer read the manual couldnt make sense of it but thatnks andy!!
rhys
Andy ·
The screw/nut? on the end of the rod is accessed when the sliding door is open. It's just inside the front end of the cover.
Not sure how to explain but quite simple when you understand how it works.
:o
