Kombi Carb troubles
https://forums.aussieveedubbers.com/threads/16375/kombi-carb-troubles
Nothing major - but
Daisy wasnt reving up the other day when in neutral or park
Turned out to be the soilenoid shut off at the front of the LHS carb (thanks Lou)
Now - Seem to have a bit of idling trouble when cold. Warms up - no prob.
Obviously choke.
The LHS doesnt seem to "spring" closed when cold. (Its the wifes car so its a bit hard to tinker or check at work, stuff on engine hatch etc) and not opening when hot. Seems loose so its not binding
The PDSIT dont seem to have the lever like on a Pict.
Is it the same choke element/spring as the Pict or Weber??
The only thing that drives the butterfly is the spring - yes??
If it isnt binding the only thing is to change the element???
Funny - Picts and Webers i will dive into and rip things to pieces. The wifes kombi is harder to get pictures of these PSDIT or whatever they are and is not as easy :jesus
kombi_kid ·
barry sounds like ull have to lend her your car for the day!!
rhys
Andy ·
Choke on PDSIT is the same priciple as on PICT but not interchangable. They are a slightly larger diameter.
If as you say the choke butterfly turns freely, a few other things may cause the problem.
Does the choke get power? If yes, it can be either the coil is broken (the bit that heats up) or the bi metallic strip is broken (the coily bit with the hook you see)
And yes, either of these means replace it
Hmmm.... sound like i just need ............time!!
Now the missus will say " if you didnt go to Dyno Day, or the beers thing the next Sunday you WOULD have plenty of time!"
As Squiz would say.......sheesh! :jesus
Flintstones ·
Blue,
If that gives you too much greif, I've got a complete 2L kombi injection system with factory computer, if you want to upgrade...🙂
Dino
check u2u
Flintstones ·
Barry, u have U2U
