rear wheel bearing replacement
https://forums.aussieveedubbers.com/threads/16386/rear-wheel-bearing-replacement
Rustbucket68 ·
Found the noise problem today. The rear outer bearing had cracked into three pieces when I removed it. I'm having some trouble removing the bearing from the housing. Are there any good tech articles on this subject anywhere? Ive looked on the forum and didnt find anything usefull.
Rustbucket68 ·
By the way this is on Shanis 71 superbug not the kombi
If its a 71 then its a IRS rear end. Take off teh axle first then you can knock out the stub axle and get a better swing at the bearing, from the inside with a long punch.
Very unusual fro one of these to break ??? Wasnt if lubricated properly
Rustbucket68 ·
There was plenty of grease, the inner bearing and spacer came out easily with the circlip removed but the outer bearing is in very tight and Im afraid of damaging the housing trying to get it out. Do you drift it out from behind?
MickH ·
Yep...with a big hammer and a chisel/long punch:alien
555bug ·
just drift out the race+bearing as a unit, slow and steady wins the race 🙂
Rustbucket68 ·
Thanks Guys, now I know Im on the right track:beer
No the stub axle pushes from the out side to the inside thats why you have to remove the drive axle with CVs... so it will push in. the circlip is a bit of a buggar some times.
