(no subject)
https://forums.aussieveedubbers.com/threads/1643/no-subject
Grey 57 ·
Yep no reason why not. As long as you remember to disconnect the power when the engines off it will be fine. Otherwise you cook the coil if the points happen to be closed when the engine stops. Why not use a simple on off switch between the coil and the battery. Could be any thing, an old light switch even.
Grey 57 ·
No worries, have fun bashing the paddocks. Wish I had a paddock to bash around in here. Havn't done that for years
Grey 57 ·
Circle work, I luv circle work. :bounce
Grey 57 ·
I'd be there in second. Only problem is once the kid was out i'd never get em back in.😀
Grey 57 ·
Nah just put a lift kit in the 57. Balloon tyres with knobbies. Sweeeeet:o
