73 comby heads
https://forums.aussieveedubbers.com/threads/16881/73-comby-heads
Ray65432 ·
i own a 73 combi with a 1800 cc motor in standard condition can anyone tell me can i remove the heads without removing the motor ? i think i have a loose valve insert in no 3 cyl . or is it easier to remove the motor /?
Menangler ·
Remove the motor, no question.
Andy ·
It can be done!!!!
Like Dave, I personally would remove the motor first, but it is certainly possible to remove a head without removing the motor.
I suppose it depends on your equipment and situation. If you have access to a good trolly jack and a cement area to do the work, I'd pull the motor. If you only have spanners and a grassy area to work in, pulling the head alone is probably better.
Just be certain of the problem before you remove the head though 😀
