Aussieveedubbers · New Members Forum
Login Glitch
https://forums.aussieveedubbers.com/threads/169/login-glitch
Buggy Boyz ·
There is a glitch with the Log In system, it will not let some login and it will not let others log out ??
Any ideas ??
Baja Wes ·
If you are having problems logging on, it may be cookie related. If you were on the forum while the admin people were making changes, you may have cookies installed on your computer that now don't work. Which basically stops you from being able to log on.
The way to fix it is find your cookies folder for your username on your computer. use the find feature on your start menu to find a folder called cookies, find your own folder if your computer has multiple users.
Once you have found it, open the folder look for a file named username@forum[1].txt or username@forum[2].txt or similar. Delete those files.
Once that is done you should be able to log on again.
btw - the username on the cookies will probably be your computer usrename not your forum username.
[Edited on 28-8-2002 by Baja Wes]
Tazzielittle ·
Blame the COOKIE MONSTER!😀:P
