having trouble with my idle (Kombi) twin stock carbs
Just did the timing (Got me a timing light and figured it out Kol) and it runs / idles nicely, but if I rev it hard and let go the throttle then it stops idling nicely and cuts out. 馃檨
if I slowly let of the throttle then its a little better
Bizarre 路
Having just gonr through similar probs with Daisy i can only suggest vacuum leaks.
Check all the pipe connections on the manifolds etc and especially check the cut off solenoid on the front of the lhs carb
I am led to believe there are a couple of rubber boots off the heads them selves.
The slow to react to a rev suggests vac leak
pyr0 路
OMG i just did this too on my bus !!!!!
try the balance rail seals .....there these 2 rubber "L" joints that come out of the bottomb of the carby and run a pipe between ( on the front side ) the carby's...
if they are perished or not on that will cause the problems you are haveing..
good luck :thumb
1303Steve 路
You will get this problem with a lean mixture, points not set right and also check the brake booster connection on the balance tube.
1302Steve
Robo 路
Could also be a faulty dashpot, this little device stops the throttle from closing too fast, and stalling the engine. its on the left side of the main conecting bar (linkage).
Rob...
