555bug ·
EJ20
https://forums.aussieveedubbers.com/threads/1696/ej20
555bug ·
Phil74Camper ·
Buggy Boyz ·
Baja Wes ·
Man that sump is rad. And people were complaining the V6 sump would be too low!!!
That SAE paper was good hey.
I got the scaling on my overlays by using 1 pixel = 1mm. I scaled the pic to suit by using a known reference like the bore/stroke.
PS - being an IT person I thought you'd have file types figured. When you do diagrams like that save them as *.gif. They will be heaps smaller files and won't get the crap jpeg fuss to them.
555bug ·
kombi_kid ·
what HP wil lthe 2L kombi box's hold? if you did a EJ20T conversion in a kombi and planted it would the box stand it? how about that same sceniro with a V6 like urs wes? or is it necessery to upgrade to a porsche boix etc?
rhys
Hutcho ·
555bug ·
as far as gearbox's go..well the 5rib 76+ kombi is the strongest box that vw produced, its weak points are third and fourth, but at a guess I imagine that it could hold 200~250hp if treated with respect, however alvins gears can be used making the box bullit proof (2k though 🙁 ) The thing to remember though about VW's is 1) there light as 2) due to the limited amout of rubber out back they are unable to produce the traction of other cars. Therefore the gearbox does not have to put up with the abuse that say a WRX could dish out (read: fat car with lots of traction) so the box should be fine. I've been in suby powerd bugs with 150+hp going throught stock twin sideplate box's that seem to cope just fine. I guess another benifit is that teh EJ20T really lacks the low down punch of other engines, only comming on song at 3000rpm so that too should help with box life.
Buggy Boyz ·
Baja Wes ·
Having said that there are heaps of V8 kombi's with stock gearboxes. The V8's put out a lot more torque than the EJ20 or KLZE, and the kombi is heavier so has more traction (especially with a V8 in the back). So basically a V8 kombi will give a gearbox more crap than a beetle/baja ever will.
I think if you drive sensibly a kombi box will be fine. But it will be hard to drive sensibly with 200HP under my foot.
The V6 has a much wider torque band than the EJ20T, so I think that will make it easier on the box. To get a good quarter mile time with the EJ20T you need to launch in it's peak torque band ~ 4500rpm. Bad for your gearbox.
The V6 on the other hand has an insane wide torque band which allows you to launch at lower rpm ~ 2000rpm and still get your faster 1/4 mile time. The V6 will allow the clutch the be fully released before the power is unleashed. If you do the same with the EJ20T you will have to wait for the power to come along.
555bug ·
Stephen
reub ·
kombi_kid ·
so what did the half cut cost u and did it include everything you needed for your conversion motor wise eg radiator, computers, wiring etc?
rhys
bugboymatt ·
I would also be interested to find out a rough price to get some parts or a half cut to do this conversion !!
Might even rebuild my oval on a irs pan with this kinda lump !!!
555bug ·
First off an ea81 in a super:
555bug ·
555bug ·
555bug ·
555bug ·
555bug ·
555bug ·
555bug ·
555bug ·
555bug ·
555bug ·
Grey 57 ·
Whats the weight difference between the T1 VW motor and the twin (4?) cam subie.
Buggy Boyz ·
bugboymatt ·
Just need to get me back to Oz to get on with it.
Hutcho ·
Could you tell me where you got the pic of the Type 3 conversion? Looks very interesting. Thanks.
Hutcho.
kombi_kid ·
is there any sites that offer conversion tips etc??? for bug and bus? it is very interesting and VERY tempting!
if only i had the money!
rhys
go to shoptalkforums.com and then go to "conversion perversions"
Lots of people into it there
kombi_kid ·
ok thanks
rhys
Che Castro ·
http://www.offroadvw.net/bajawes/linktoV6.htm
[Edited on 15-11-2002 by Baja Wes]
Baja Wes ·
Hey Brad - do you have a brother called Wes LOL
Man...i want a schooner for everyone that has called you Steve...no ...John...or was it Brad
Che Castro ·
Quickbug ·
It aint gonna happen...
Minimum $8grand PLUS engine and loom...
DAMNIT!!
I WANT ONE SO MUCH!!
kombi_kid ·
and DIY its much cheaper!
rhys
Quickbug ·
I might have to ring a few other places to see what they say pricewise...
Coz for 4K im gettin it!
555bug ·
Doug Sweetman ·
DIY is the way to go IF - you have the skills, time and alternative transport.
That said, go for it - the EJ20T is a joy fun motor even bog stock 🙂
Hutcho ·
Why dont you look at getting one of the older Subaru motors, like an ea82t or an ea81t. Theyre much cheaper and not as complicated as the EJ motor.
Hutcho.
speedster356 ·
555bug ·
[Edited on 19-11-2002 by 555bug]
Quickbug ·
Will have to look into it a bit more...
What car did this engine come from?!?
Is there much potential to work this engine??
Would it need to be rebuilt before fitting it up? ie how old is this engine?
I sooooooooo want a turbo bug, i love the PPPPPPPPPSSSSSSSSSSSHHHHHHHHHH!!!!!!!!!!!!!!!!!
lol
Another thing - can anyone clear up and intercooler question?!?
Is mounting an intercooler in the front of a bug and running piped to the engine a problem? Seems like a long path for the air to travel is all...
speedster356 ·
As for the PPPPSSSSSHHHHHHH...it really does get to you after a while. I'm trying to get less PPPSSSSHHHHH on the Spyder!!!!
[Edited on 19-11-2002 by speedster356]
555bug ·
kombi_kid ·
rhys
Quickbug ·
lol...
Gotta admit i love the sound of an external wastegate....
My car already shoots fireballs - its always a big attraction when cruising - everyone pesters the crap outta me till i give it a bootfull and back off to send flames everywhere....
I'm really interested in this engine - sounds like it could be a viable alternative...
*fingers crossed*😀
twobus ·
Cheers😉
speedster356 ·
I'll measure my engine this evening and post the results.
[Edited on 20-11-2002 by speedster356]
speedster356 ·
555bug ·
555bug ·
Pat ·
Hutcho ·
Here are some dimensions as well.
Ea 81T: Centre crank to bottom sump=240. Centre crank to end rocker=320. Centre crank to top motor=340. As you can see in the pic, the alternator goes past the rocker by 70mm.
The VW motor: Centre crank to sump bottom=190. Centre crank to end rocker=380mm. Centre crank to top of motor (Type 1 oil cooler) =400mm.
So, the Subaru motor is actually smaller than the VW motor, except for the sump on the ea which hangs 50mm lower.
Regarding the intercooleer question, I think a water to air setup would be perfect for a VW. These setups are better for street due to the low fluctuations in intake air and you dont need a crap load of fresh air blowing through the front of the car to get the best performace from it.
I just picked up a whole RS liberty intecooler setup for $200!! These guys all want the look of a big 'cooler out at the front of thier cars, so thier giving thier original setups away!!
Hutcho ·
Hutcho
Quickbug ·
I'm drooling at the thought of one of these engines...
I'm gonna talk to a shop down the road that sells the ea82t's amoungst other things and see what prices im looking at.
Do you guys recommend running the original wiring loom? I intend to upgrade later but cost is a factor atm...
Have to see how much my mechanic reckons the conversion will cost...
Hutcho ·
Wiring can be a s@#t. When you get the motor, also ask if it comes with the wiring, ecu and knock control sensor. If you can get these, it'll make your life a hell of a lot easier as an aftermarket one will cost the same as the motor itself or more. Where abouts in Sydney do you live (I live in Ingleburn)? If your serious, you could come on over and we could yak and you could see for yourself what is involved. I dont know what kind of relationship you have with your mechanic, but it would probably pay for you to ring around. Ask other people that have done it which mechanics they got cooperation from. This has already been mentioned, but you should be able to get out of it for about $2500 to $6000 depending how much you do yourself and who does it. The guys on this forum ARE a wealth of info, so use them, they love it!
kombi_kid ·
rhys
Quickbug ·
I have always used the same mechanic for my vw's and had heaps done with him but i defiantely intend to call around since i just spoke to him about cost for fitting the ea82t and he says it will be about the same as fitting an ej20t?!?!?!?!🙁:o
I was thinking along the lines of picking up the engine with wiring loom etc so thanks for the backup there...
I cant do much myself - im not good with mechanicals so i'd have to pay drive in drive away costs....
Hutcho ·
Steve.
Hutcho ·
Depending which motor you purchase...
I was very recently quoted $1200 for an EA 82T, but to be honest, I dont know if it came with wiring and ecu's. Id just ring every Jap import place that you have in your phone directory.
Hutcho
555bug ·
speedster356 ·
kombi_kid ·
i live in a country area so no jap places around here🙁 will have to get on the phone and ring around when i get a bit of spare time.
if people get prices can they post them here? and where do people place the intercoolers in a kombi what conditions do intercoolers need?
rhys
reub ·
The engine cost him $600.00, he picked up a microtech digi series 2 (which I believe are fuel only ecu's) for $500.00 and sent it to microtech for a subaru fuel map. He removed the distributor and replaced it with a standard electronic ignition distributor (not sure of the engine it came from). He also replaced the inlet with a ram pod. A Saab bosch blow off valve was installed for about $50.00. I think he made his own adapter plate and bought a flywheel and clutch from sherman in QLD. It ran a standard swing axle rear end with ea falcon rear brakes and twin pin vw front brakes. With a bit of patience he made up his own wiring loom for the car.
Even though it's only run a high 14 at the drags it is easly capable of blowing away most cars at the lights and is a great budget alternative to an EJ20. I'd suggest this conversion use a standard engine as I can't see the point spending mega dollars trying to enhance one.
Just my 2 cents worth.
555bug ·
hey speedster..the benifit of the water cooled intercooler on a vw based car is that (obviously) water can absorbe loads of heat energy in relation to its volume..you can pass this water through a small motorbike intercooler although it actually make little to no difference 😉 as with my application getting sufficent air flow through a bar and fin cooler is often not possiable (although I think I have a way around this)..anyway back to the topic..Ummm yup the only drawback of a h2o cooler is that after a few hard runs the cooling system is heat soaked so its actually warming the inlet air..anyway you really have to look at your application..if your racing then you need constant cooling as you'll spend a great deal of time at WOT, if drag racing then you're only looking at >15sec at constant WOT or on the road with occasional spurts. Anyway the thing is the cooler the charge the more power you can make + any intercooler is better than none..the liberty cooler can handle 150kw so that should be good for you..or you could get a series5 RX7 cooler and add a water spray kit that activates at WOT. Anyway heaps of options check out http://www.gnttype.org/techarea/turbo/intercooler.html
for a detailed explination of all things ..that cool.
reub ·
kombi_kid ·
rhys
555bug ·
http://www.ultimatesubaru.net/80s/specs/mechanical/engine-specs.html
[Edited on 22-11-2002 by 555bug]
555bug ·
amazer ·
I dont know what you are saying here. How does the subaru cooling system work. Do they have a seperate water system (pump and radiator) for the intercooler or is it the same engine cooling water used in the intercooler? And the way I read it you dont cool the intercooler water at all?555bug wrote:hey speedster..the benifit of the water cooled intercooler on a vw based car is that (obviously) water can absorbe loads of heat energy in relation to its volume..you can pass this water through a small motorbike intercooler although it actually make little to no difference 😉 as with my application getting sufficent air flow through a bar and fin cooler is often not possiable (although I think I have a way around this)..anyway back to the topic..Ummm yup the only drawback of a h2o cooler is that after a few hard runs the cooling system is heat soaked so its actually warming the inlet air..anyway you really have to look at your application..if your racing then you need constant cooling as you'll spend a great deal of time at WOT, if drag racing then you're only looking at >15sec at constant WOT or on the road with occasional spurts.
I have used both water-to-air and air-to-air in both road cars and race cars. In the race car the water was crap. USELESS! Cos I'd have a "run" and every thing would be fine. Switch the engine off while waiting for the next run, and the whole time the water is soaking up heat. Then when the time come for the next run there wasnt enough time for it to cool down, and of course sitting in the pits there is no airflow. Spent money boxing in my air to air then cut it off again.
On a road car things are different. Air to air was good enough, but water is better. You're never on the gas long enough for things to get too hot, and there's a constant airflow past the radiator keeping things cool. You must have this water circulating through a radiator though. My kombi was overheating when my pump wasnt working. The hot intake air was killing it. I guess this wouldnt be as big problem with a subaru engine though.
If you have enough room for a radiator to cool engine water you should have enough room for something to cool intercooler water. mount them in the same place. Im using a corolla radiator (from wreckers) mounted flat to the underside of my kombi. Its got no scoops or fans forcing air through it yet it is cold all the time. Never even gets slightly warm. So I'm guessing that something from a diahatsu or 121 which are half the size and only about 1/2" thick would be up to the task.
I'm still yelling "BOOOOO" at using non VW engines though. Even if I have compromised my own principles by adding a water pump. :jesus <- jesus knows I'm still air cooled at heart.
kombi_kid ·
whats the ristrictions to what lenght an intercooler can be mounted to from the motor???????
rhys
amazer ·
kombi_kid ·
rhys
