I have a 2 litre Kombi with 009 distrubutor. I have just brought some points but am not sure on the gap I need to set it to.
Please help.
Andy ·
Not sure if it's the same for a 009, but SVDA dizzy on 1600TP and all type 4 kombi's is 0.4mm
Also good to check dwell if possible (44-50deg).
Is the motor otherwise stock, and does the 009 run OK?? For an otherwise stock setup a stock Dizzy is best.
Andy
:thumb
Set the gap to 0.016" on number one position same as a standard set up.
The timming may vary depending on whats been done to the engine etc etc
You may have to try a few positions to make sure it does not ping
