who knows if I need to put a resistor in when fitting?
jakriz ·
No u don't, I don't have one on mine & it's been going for 6 years now.
regards
Jak
robnjo ·
oops sorry what I meant to say/ask is do sbugs have a "resistance wire" in the loom,I'm not sure as I don't have a manual to check the scramatic diagram.does anybody know or have manual to check for me please.
ROB
Grunk ·
I've been bugging any body possible about this as well - no one seems to have had any problems running GT40s, standard coils etc - the only thing I can come up with is that most people seem to agree that German / genuine plug leads give the least problems. I can't find anyone who has actually fitted a ballast resistor. Some with compufire ignitions have had troubles with silicone leads - but no probs with stock. I've gone back to stock leads and will soon fit compufire. After that will replace stock coil with GT40. See what happens from there......:o
robnjo ·
I run the trick coloured leads that are "copper cored" cause somebody had mention that(silicon leads) as well.
ROB
jakriz ·
I also run a standard GT40 coil & top gun leads from Autobahn & have done so for many years.
regards
Jak
robnjo ·
hey jakriz, do you know if there is a resistance wire in the loom on a sbug?...it just that this COMPU FIRE kit has in the instructions "that a suitable BALLAST RESISTOR must be installed between the ignition switch and coil"
I 'd hate to fry the new module thats all
ROB
