Kombi was running rough and would not start. 11Cab came over and checked everything out. Established that spark plugs were stuffed. Fuel was OK. Put in two new spark plugs and went OK.
I put in the other 2 spark plugs in and new points and now it wont start.
It is 2 litre with extractors and twin dellorto carbs.
I have set points at 0.016".
Any one have any idea's on what could be wrong, PLEASE HELP.
kombikim 路
probably better to set points a bit wider (up to .020), sounds like you missed putting a connection back somewhere, did you put the rotor button back on? stupid question , but many people caught by this, also , turn engine until points are closed turn igniton on & open & close with a small screwdriver to see if there is a spark & they have power馃檨
72TWINCAB 路
Rotor button is in. Will set points wider and do the spark test.
Let's hope it works.
Thanks kombikim.
kombikim 路
the wider gap wouldn't make it start, it is just better to set at widest specified gap initially as the points close up slowly as they wear
72TWINCAB 路
New points were'nt sparking real well. Put in old ones and they were sparking better.
Still won't start though.
kombikim 路
they are not supposed to spark much, that is the purpose of the capacitor, I assume the engine doesnt even cough & that you have checked that the timing is correct, because it changes substantially when you change points
YOU CAN RING ME ON 1800150522
72TWINCAB 路
Have'nt checked timing. Thought I had to get it started to do the timing.
How do I check timing when I can't start it?
kombikim 路
ring me free 1800150522
72TWINCAB 路
Got it going. However I now have a flat spot at high revs. Any ideas.
Bill
kombikim 路
it is the 009, most likely
connect the timing light & see what reading in degrees the highest advance is, should be 32 degrees I think, at about 3500 revs
72TWINCAB 路
With timing light, it is idling at about 16 deg and when I rev it, it advances to about 40 deg. Not sure how many revs thats at though.
72TWINCAB 路
Adjusted the timing back to 10 deg. The advance is now about 32 deg. Took it for a run and the flat spot has gone.
All seems well:bounce:bounce:bounce:bounce
Thanks for all your help馃榾
Hope it starts OK tomorrow
kombikim 路
take it back to 10 degrees at idle
72TWINCAB 路
Have done. All seems well. Thanks for your help. Your a legend:thumb
kombikim 路
thas ok get 11cab to have a quick look to optimise it when he gets back though
72TWINCAB 路
Sure will馃榾
72TWINCAB 路
I've been away for a few days and this is where it's at.
Well the kombi didn't start again the next day and I have'nt been able to start it again since.
I seem to be able to get it started with a bit of stuffing around, but it goes back to it's old ways after a sleep and won't start.
Have a look at the picture of the crap new points i got.
Dont think cause you put new points in you have fixed something.
Take the points out of the holder and make sure they have spring.
I know it is a bad picture but you can see the things i bought were almost touching when new.
sand kombi 路
are you a RACQ member,if so give them a ring, if not join then give them a ring.
a cheap type of insurance, I've been a member for around 25yrs, don't use it often but it's handy to have
72TWINCAB 路
UPDATE
The coil was the cause of the starting problem. After installing new coil in the beast it starts first go every time.
It was running rough though. Installed new condenser and petrol filter and she is running like a dream.
Thanks for all your help everyone. 馃榾:bounce馃榾:bounce馃榾:bounce馃榾:bounce馃榾:bounce馃榾:bounce馃榾:bounce馃榾:bounce
Bizarre 路
We should do a back search on how many times the coil has been the culprit!
I know it was the cause of my Webers misbehaving in the early days.
mnsKmobi 路
I can't work out why they bolted the coil to the motor. in the first place!
"This gets hot, how about we bolt the coil to it?"馃榾馃榾馃榾
11CAB 路
Hey Glen, did you have fun putting the condensor in?
Good thing we got it going for the move......thanks mate. :thumb
72TWINCAB 路
Yeah got the condenser in with not too much trouble. Kombi is still running rough intermitenly (spelling?) though. Will change points and re-do timing tomorrow. Hopefully will solve problem.
No worries with the move 11cab. Let us know when your ready for the next one
72TWINCAB 路
Put new points in and timed it. Running like a dream now:thumb
It's amazing the difference a new coil, plugs, points, petrol filter and condenser make to the running of a car.
