Very neat job of the taillights!
Da Wiz wrote:Looks neat, has anyone played with the idea of using LED tail lights [ snip ... ]
I've got an LED interior light in the truck. It replaces the 41 mm incandescent "festoon" lamp with a bulb made from a printed circuit board with three white LEDS, a diode and a resistor (kit from Jaycar). You can't get them assembled, although some other configurations such as multi-led turn signals are available assembled. Each of the LEDs is 7000 mcd (microCandela ???) in brightness. The end result is about the same brightness as the $1 incandescent bulb, a much whiter light and should last forever, which is just as well as the replacement bulb cost $35 in parts (principally the LEDs, at $9.50 a piece).
About the brightest LEDs available are 15000 mcd, but I can't find any available at the moment.
There are PCBs and info. available at Jaycar.
Happy soldering.
