Aussieveedubbers 路 Tech Talk
ecu ? can some one start me going ?have now found the motor the same as Dans unit !
https://forums.aussieveedubbers.com/threads/17251/ecu-can-some-one-start-me-going-have-now-found-the-motor-the-same-as-dans-uni
seagull 路
can some one start me on this ecu lay out thanks I can not find the ecu in the wiring diagram I just need the page number from www.saxonfields.freeserve.co.uk this is on the scubi page ej20 quad cam .thank you seagull
555bug 路
what type of engine did you get, JDM or aussy? also I was wrong 99+ models are equipped with OBD2 so chances are that you have odb1. Anyway what have you got 馃檪
seagull 路
u have u2u thanks seagull
this a jap import was a auto so it will be a few years old it has done 83 k I have now found out that this is the same motor as dan,s unit col has told me he has a copy of the wiring diagram and will foward it on to me , I ask Col if he can post it on the web good work Col , if you come to perth I give you a drive thanks seagull
