1973 Kombi camper engine
https://forums.aussieveedubbers.com/threads/17334/1973-kombi-camper-engine
nzkombi ·
I have got a 1973 kombi camper, 1800cc and the motor has been
reconditioned and i am tuneing it at the moment. it has got twin cabs
and is air cooled. when it is at idle it is running really rough on
3and 4 port (i can take the leads off and it makes no diffence) .
Can you help me to run smooth. i have put new points in, changed the
leads over and cleaned the cabarator on the 3 and 4 port side, put a
mew condencer on but it is still running rough. Have you got anyideal
what the problem is? please can you help me. thanks.
Menangler ·
Hi, check your idle solenoid on that side, it has a wire going to it, turn the ignition on and pull the wire off, it should make a clicking sound, also make sure it is screwed in tight, they can come loose.
Astro Boy ·
mine did that when one of the valves was gone, but considering it has been reconditioned......
