only runinng on 2 cylinders
https://forums.aussieveedubbers.com/threads/17369/only-runinng-on-2-cylinders
kombi_kid ·
hey
we have a 1500 type 3 motor with dual carbs on it.
it is only running on cylinders #3 and #4, #1and #2 are dead.
we have replaced the plugs,leads,condensor,tried a different dizzy,set the timing several times ,done the tappets and it has strong compression
what could be the problem??
rhys
SKEWtYpe3 ·
is it running realy rough and pushing/bouncing from side to side?
mine with same setup was doing this, a carby jet was stuffed............flooding constantly until hi revs when it kinda stopped
hope it helps
kombi_kid ·
the funny thing is it sound like its running fine but lacks extreme amounts of power (max drivin speed is 30mph).
the carbies where rebuilt will check for jetting
rhys
Make sure the all the linkages are hooked up correct.
make sure the vacuum balance lines are not cracked and are tight on the mainifolds etc etc
kombi_kid ·
ok problem solved!!! thanks skewy u made me think i checked the carby we changed the jet in and noticed out the corner of my eye there was no fuel!!!
bloody blocked up at the "T" section!!!!
thanks for your help guys
rhys
SKEWtYpe3 ·
:thumb
The simple things always stop you.
kombi_kid ·
we have done so much to this motor and didnt check that!!! definately learned something!!!
rhys
