I need to touch a couple of stone chips can I use acrylic over the twopack as I believe two pack is not good as a touchup paint as it goes off in the tin whats the best bet?
Thanks for any answers.
mITcHeLl馃槑
helbus 路
Yes you can use acrylic touch up over two pack. If the touch up goes all wrong, you can wipe it off again using prepwash while it is still soft and not affect your two pack paintjob. Then have another go.
Two pack can be used also without a catalyst added, but it wont harden as much as if had hardener added.
waltermitty 路
Thanks hellbus, so what do you recomend? Acrylic or Two Pack?
Regards MitChelL
