Oil temp senders
https://forums.aussieveedubbers.com/threads/17495/oil-temp-senders
I have an SW oil temp gauge in the car. It use to be hooked up to a sender in the rear oil pressure relief hole.
I now have another sender that looks different and is located in the sump through the case.
Can i just hook this up to my gauge???
Reckon they are a compatible sender/signal???
Will it burst into flames and set the mag case alight if i just try???
Should i just put the old sender back in???
I just prefer the location of this other sender.
I would actually like to compare the 2 temps at different locations
BARRY
Just attach the bloody wire will yar and stop stuffing around.
when the engine is hot take a temp reding of one sender bulb then change the wire over to the other type one and see if theres any difference.
Use the difference for a calibration point if necessary.
just bloody drive it, how hot can a 1776 get !
So what if the two read different, do you fit a third:jesus and then a fourth for good measure 😀😀😀
lugnuts ·
What ^ both said :P
fish ·
yeah !! what they all said!!! drive the bloody thing. if it starts farting around, stop, let it cool off , and then off again. it's a bloody VW, goes for years.
jakriz ·
If I can use 94's & keep my motor cool, surely u can stay cool with those 90.5's.............
Menangler ·
Hey Barry, their a crabby lot this morning, I think you just got heaps 😀
Must be that time of the month!
blutopless2 ·
Temperatures measured from different locations will always give a different reading depending upon the flow of oil past the sender unit. It is the way they are mounted that is important and how sensitive you want them to be to temperature fluctuations that determine where and how they are mounted.
bigbruvabob ·
out of interest jak riz what does a cool set of 94,s run at and how long will they stay that cool at various engine loads. i thought you had a 1880? ddo you run an external cooler and/or propped boot lid. i am going the 94's route but overheating is a particular phobia of mine.
Peter Leonard ·
with stock cooling system my 94s rarely pushed my temp over 110 on hot days. which is fine. 😀
*pushes past jak in hurry to blurt out findings*
