Pedal throw distance
https://forums.aussieveedubbers.com/threads/17760/pedal-throw-distance
Quoll ·
G’day,
I was wondering if it’s possible to adjust the position of the clutch and break pedal as I am tall and it’s fairly uncomfortable to operate the clutch pedal in its present position any suggestions?
I've attached I diagram showing what I want to do.
What year model car is it,
The early pre 67 will have to be heated up to bend them as there a cast pedal
The later pedals are usuall pressed steel and can probally be bent using a lever.
both pedals should be that same distance or level together at the rubber pads. this is adjustable on the floor.
Quoll ·
How would I go about doing that
Thanks,
Justin.
Pull the floor mats up and below the brake n clutch pedals on the floor you will see 2 x 13mm headed bolts
these are loosened and the pedals can be mooved or levered into position and the bolts re tightened
theres no pressure on the brake pedal so its a good idea to back of the clutch pedal adjustment at the gearbox end so you can moove the clutch pedal more easier.
Then re tighten every thing
