Hi, we have a 76 kombi, we also have a baby due in 3 weeks and with myself and now my wife being on the larger side, we only have a about 20mm travel before the car bottoms out. The car rides and steers well, Do I need new shocks? if so what is a good option- gas/air?
Also this is a camper and with more and more camping equipment becoming available for campers I am thinking the rear may have to be beefed up a little also,
Has anyone had to do the same?
thanks Col and Nat
Purple Martin ·
Shocks have no effect whatsoever on ride height! Shocks simply dampen sudden up/down wheel movements as you go over potholes/bumps. They're not weight-bearing at all.
you could always fit AIR Shocks, you can then pump up your height at the service station !
If the same amount of weight is always in the Kombi, then raise the height of the car by having someone adjust the torsion bars etc.
Andy ·
Front is non adjustable (if it's stock), so either you have a broken leaf or two, or they are badly sagging. Best to replace the bad leaves in the front tubes.
Rear is a simple matter of adjusting the torsion bars by rotating the torsion bars on there splines.
Both jobs can be done at home, but not a job for the faint harted or not mechanically minded
:thumb
