Swap 2.0 for 1.8?
https://forums.aussieveedubbers.com/threads/17877/swap-20-for-18
Purple Martin ·
What's involved in replacing a 2.0L kombi motor with a 1.8L motor? Presumably it won't just bolt on to the gearbox...
Andy ·
This has come up often, so double check with old posts!!
From memory you need to swap flywheel & clutch to run a 1.8L motor on the 2L GB.
:thumb
Purple Martin ·
Yeah I did try the search function but got nothing.
So do you mean that if I got the flywheel and clutch along with the 1.8L it would bolt straight onto my gearbox? That sounds do-able!
Andy ·
The way I try to remember it is think of the GB + clutch + flywheel + starter as one unit, and the motor without flywheel as a unit.
Then you can swap them over.
Can anyone else confirm this is correct??
:thumb
11CAB ·
If you swap the Bellhousing, Input shaft & Starter Motor with 1800 items then the 1800 motor,flywheel & clutch will bolt in
