Respray of Beetle - step by step with pics part II
https://forums.aussieveedubbers.com/threads/17886/respray-of-beetle-step-by-step-with-pics-part-ii
helbus 路
This is the original pic of the Beetle as it looked 30/12/03
馃檨
[Edited on 9-5-2004 by Helbus]
helbus 路
This is it now just finished today.
馃榾
helbus 路
This is the rest of the process I went throgh to get it to where it is now.
This is showing the sander with a soft back up pad with 600 dry grit dry paper after sanding with 320 dry and putting charcoal dust on.
Dry sanding is preferable these days as it it is much cleaner. The paper is a little dearer though.
Softop 路
Verrry nice Peter!!
Roger
helbus 路
This shows the masking of the inside of the panels which were painted black. This is the bonnet now ready to be painted outside.
helbus 路
All of the outside panels in the oven ready to be painted.
helbus 路
The outside panels painted.
helbus 路
The white had already been painted before and was masked up when the top of the doors was painted.
helbus 路
The main car in the oven ready to be painted. Masked up with plastic and paper.
helbus 路
Sprayed tar under the guards before they were put back on. This will help prevent rust.
helbus 路
The luggage and engine bays in satin black.
helbus 路
Ready to put the guards on after measuring and cutting out the notches in the fender beading.
helbus 路
A few shots while moving the car around and assembling.
helbus 路
When I put the new door trims on which I procured from Volkspower.
I masked up just in from the edge of where the trim would go, and applied some spray adhesive.
This was so I could put some plastic on, which stops any moisture from getting into your vehicle and ruining the trims.
helbus 路
With the plastic glued on and trimmed and the tape removed. Ready for the new door trims.
helbus 路
Putting the windscreen in.
This is the same for all of the windows, but the windscreen is the hardest. It is a little nerve racking, as they can break easily. Although I have never broken one I still get nervous about it.
This is showing the method of putting a string in the groove on the outside edge of the rubber. This is looking from the inside of the glass.
helbus 路
This shows the screen with the string in the groove all the way around.
I always do a loop at one side as well as the ends on the other, so I can start from two spots. This is very important to keep the screen centralised in some way.
On bigger screens I do a loop on all four sides.
I use masking tape to hold the bits of string inside.
The string is about 4mm diameter and ideally sash cord or lawn mower starter cord is preferred. The string I have used here is only just ok.
helbus 路
Then apply some mastic sealant to the outer edge of the rubber where the lines are. Do this after putting the string in, so you dont make a mess.
helbus 路
This shows when I am starting to pull the rubber at the bottom of the screen. Once it starts wrappin around, I do a bit at the top as well to centralise the screen.
When you first drop the screen in the car, you may need a friend to help, so you dont drop it.
helbus 路
This closeup shows how pulling the string brings the rubber lip from the outside to the inside. This picture is taken from about the drivers seat.
It is important to pull the string towards the other side of the glass, and not just back towards you.
Here the string is being pulled up directly toward the rear view mirror, not back towards me in the drivers seat. If you do it properly you have less risk of tearing the rubber.
helbus 路
A light slap and gentle push on the glass from the outside to make sure it is seated properly.
That line is a reflection, not a crack.
helbus 路
A bit of tar on the floors to protect them, as thay had a little bit of surface rust on them.
helbus 路
The Beetle is all finished except for a little bit of trim work below the back window's and new carpets. I will then be able to put the rear windows in.
I has taken about 20 days - in my own time after hours and Saturdays while working during the week. I did not get any holidays, nor did I work on any Sundays.
Cost $400 for paint
$400 for assorted rubbers and 4 inner/ door trims so far.
The carpet and other trim bits will cost about $400 also.
So for a total of $1200 this has been a budget build up. There is a questions thread for those who are so inclined. Stay tuned and this concludes our broadcast for today. 'click'
helbus 路
I found a few pics from when I did the rust on the 'A' pillar, so I will post them when I remember. :thumb
Stanley 路
Looks great Peter, 2 questions what "tar" did u use under the guards and on the floor and what are your thoughts on electric orbital sanders for removing old paint prior to respray.
helbus 路
Underneath I used Sikaflex 'underbody sound deadener'
It is very tarlike and needs a coat of chassis black on it to finish it off.
You cant paint anything else on it as it is really flexible. It is runnier when you put it on but then it dries it hardens, but not so hard it it can crack. Takes a day to dry and will still be a bit sticky on the surface even after that.
An orbital sander will be fine. It is all in the way you use it and how thick the paint is you want to remove.
I used 80 grit where I wanted to go to bare metal and 240 grit where I just needed to sand the original paint to remove scratches or chips. 馃槈
CB Hotdog 路
Nice paint job - you make it look easy!! Me and my boyfriend are considering whether to go through all this (or not??). Do you hire a spray place or are you a professional? Where do you do all this and get all your gear?? I am in Melbourne (any suggestions).
helbus 路
I was doing at a panel shop where I was a manager for a year and a half. The shop does strictly accident repairs. I have since left there and left the trade as there is no love or money in it anymore.
No suggestions sorry, unless you want to pay upwards from $5000. I personally do not know anyone who will do a good job for under that much these days.
paulgrey 路
Hi,
I have been setting aside some cash to respray my beetle, I what to keep the same base colour but have been thinking about apply a few clear coats to give it a real shine and some protetion. What are your thoughts on clear coating... Yes/No, how many layers etc.
Also the Tar under the gaurds will that help prevent stone brusing on the gaurds?.
[Edited on 31-10-2004 by paulgrey]
helbus 路
Clear is only really necessary on COB (clear over base) paints. This includes metallics an pearls. You can make solid colours in COB, but again it is not necessary. You cant really just clear over existing paint on a car, you will have to put some colour on it first. If it is the same colour, then not as much colour will be required.
Yes the tar is thick and should help prevent stone bruises. It is also a little bit soft, so should help bounce them rather than letting them put star cracks in the fenders.
paulgrey wrote:Hi,
Mikey-56EJ20T 路
Hey. Wicked job on your bug. Just wondering how you go about getting enough primer and colour in through the grills under the rear window?? I am just prepping my 56 and the question came up.
Mike.
helbus 路
Just try your best to get the paint in there. Lower pressure and thinner paint.
76bug 路
wot ratio of paint to thinners u use?
thanx
helbus 路
76bug wrote:wot ratio of paint to thinners u use?
thanx
Being two pack paint, the hardener thins the paint also. I use as per instructed for that brand of paint. PPG Deltron. 1 part hardener to two parts paint. Then add between 5% and 10% reducer (thinner)
More reducer helps the paint flow, but slightly dulls the finish and requires some polishing. Less reducer gives a glossier but slightly more peel finish.
As the solvents are released from the curing paint they reduce the gloss. Therefore more solvents equals lower gloss. This does not mean no solvents means top gloss. There are parameters to operate between. that is the 5-10% for this product.
There are many other factors also to consider. Humidity level, ambient temperature, surface area to be coated, finish required. No rules or books, just a bit of experience to top it all off.
splitty60 路
the beetle looks great peter
i am doing one up know a 63
i would like to do it the same colour
if thats all right with you i am in perth
splitty60
helbus 路
The burgundy colour is a Ford colour used on about 1995 Fairlane. name Bordeaux. Code is B8 (as in 'Bee' 'Eight' if that is hard to read) The white is standard 1970 Beetle white. I've forgotten the code sorry.
helbus 路
This is this Beetle now. No fault of the driver of the Beetle though.
floss 路
those colours look great
floss 路
hadnt seen the last pic...ouch sorry to hear it
aussiebaja 路
she looks sweet fantastic job
greedy53 路
dam good and easy to follow do a whole dvd on bug shit
69bug 路
How much did this set the owner back.approx?
helbus 路
69bug wrote:How much did this set the owner back.approx?
About 80 hours labour, so in a panel shop at $80 per hour, there was about $6400 labour. Plus materials, and you have about $9000 paintjob.
hus22l 路
Hi Pete, great thread!
I am working on a 67 type 1 project. This is very useful, i am the stage where I have finished some body repairs and have painted the car with high fill primer. I dont want to paint my car myself, but want to cut down on prep time for the painter. How many coats of high fill primer would you recommend? (i am using 2k paints).
Also are there any other suggestions you could give as to prepping up to under coat stage?
P
Topaz 路
Awesome!!! Is this your wifes beetle u r doing up, or is it another project? Goodluck peter. 馃憤
Pacific-Dubber 路
That is very good on the labour time, it adds up realll fast. 80 hours is good to get a whole car painted to say the least.
Two pack has made the finish a lot easier to acheive than the old acrylics. Though I am not a fan of these as they're super toxic and I don't own a booth. I suppose sooner or later I will have a go at two pack. (My paint supplier tells me once you try it you never go back.)馃槑
I noticed you used that Sikaflex paint on the floor pan. I am a bit gunshy of the product as in the body/seam sealer. Its runnier than another brand I have used. I got 'caught' last time I did a job as teh stuff ran like warm toothpaste everywhere 馃檨 and it took some hours to clean up the mess with thinners. 馃槵
Sad to see the damage from an accident. Hopefully not too bad on that inner fender area. A good thing is you have the knowledege 馃檪.
Ian
