I accidentally dropped my generator when I was cleaning it. I landed straight onto the shaft and cracked the metal. Is this beyond repair? If so, has anyone got another 12V gennie I can buy off em?
sigh
vwtyp2 路
that's what we refer to in my game as "N.F.G"
but you can apply that term to whatever you want.馃檨
Bizarre 路
Tofu
i have one you can have for $50 + freight
I know i am in Sydney but IF you cant do better then give us a call.......
TTFN
Barry
oval TOFU 路
nfg? not phuqing going? naturally flacid genitals? never phuqing goes? no furry goolies?
so I take it that the generator is gone to the big generator graveyard in the sky?
I'll let you know how I go blue! Thanks dude..
Anyone else with offers of good working generators? or advice? :thumb
1303 路
The generator itself is probably still OK,just looks as though the bearing housing has taken a beating.If you take out the 2 screws located behind the pulley, you can remove the bearing housing and replace it.Just make sure when it is off that you check the armature shaft isn't bent and all should be good.
Cheers Paul
oval TOFU 路
the side plate that is cracked doesn't have the screws, that is on the other side... can I still replace it? I fiddled with the armature shaft and doesnt seem to have any freeplay - good news perhaps?
karmannghia60 路
That's a real bummer Chris 馃檨
vw54 路
looks like you just need the end cover bearing housing. Pull it apart n check to see if anything else is damaged make sure the armature isnt bent.
oval TOFU 路
fingers crossed then, I'll check it out tomorrow...
Grey 57 路
Chris I have a stuffed 12v gennie you can have for the parts if you need it. The armature is burned but the housing is all good.
oval TOFU 路
I undid the two really long bolts that holds the two end plates together and the bent end pretty much fell apart... So its just hanging on by the bearings onto the shaft... Can I remove this?
hey grey, I might take you up on that offer! We'll see what happens...
oval TOFU 路
bump:alien
Peter Leonard 路
while you're in there and fiddling with piccies, how do you lube the bearings and what with? anyone know? mine's starting (after quite a few years now) to get that whine and i'm hoping to just pack it with greasy sh1t to save its leedle life for a bit longer...
:jesus
failing that, I'm thinking of replacing with one of those new 55 amp bosch alternators
mmm crackling sparky blue powerrrr *drools*
oval TOFU 路
Dunno about lube. I thought the bearings were sealed... but what do I know anyway... I cant even fix this stoopid gennie of mine!
oval TOFU 路
bump
do I need to buy a new one then?
Peter Leonard 路
yes. an ALTERNATOR.
charges at low revs, more efficient, built in voltage regulator. sounds like a great excuse to bolt one on 馃榾
oval TOFU 路
yeh, but for how much? about $250? :cry
Peter Leonard 路
dunno... i put mine on almost 6 yrs ago..
has been fine apart from once being struck by lightning. but that'll do it. fried the inbuilt regulator. 馃榾
so at less than 45 bucks a year i reckon it'd be worth it at 250 bucks.
