graeme86 ·
I have dual 40IDFs. Current issue is: whilst idling, one cylinder thoat can be blocked off at the air horn with no effect on the idle speed of the engine. The idle mixture screw for that cylinder also has no effect. The idle speed is steady however. Also RAW, and I mean RAW fuel is coming out of the exhaust pipe - enough to wet the ground where the exhaust points to! Spark is present at that cylinder. I have replaced the following:points,plugs,dizzy cap,leads,coil and carbs have been professionally soaked, cleaned and blown out. Any ideas? Help!!!!
