In the near future, mabey this weekend perhaps I plan to take the Dog-O-War (71 Baja) to a mates to get some work done. The main thing is replacing the tranny rubbers and strapping the tranny down tighter to limit further wear. I also hope to get done or at least be shown who to replace my master cylinder and install a carby kit without stuffing it so it should be a good learning curve provided I leave the beers to later on.
Anyhow, what I'm asking is, should I take along other stuff that could / should be done while the motor is out and the transaxle is under the microscope. An example Ben put to me is to grab a main bearing seal and do that while your at it.
What else do you all suggest?
check the clutch, pressure plate, end float, and oil cooler seals, and engine mounts as well.
Doug Sweetman ·
Clutch throw out bearing and clutch fork too. I've had both fail on me before.
Will prove an intersting weekend for you 🙂
The_Bronze. ·
Have noted all that thanks. Have been looking forward to it for weeks, not only to the the Dog running better but to put a lot of this read theory into practice.
Andy ·
If your replacing the main seal, I'd also replace the Gland nut which has the pilot bearing in it. I would also check bolts torques while there easily accessable.
:thumb
11CAB ·
Should probably put a new input shaft seal in the gearbox too.....and if the axle boots haven't been done in a while its much easier to get to them with the motor out :bounce
