Making a beetle steer and handle
https://forums.aussieveedubbers.com/threads/18797/making-a-beetle-steer-and-handle
Adam_C ·
my beetle is lowered, i have a few questions...... some silly but eh im just curious
what can i do to improve the ride, and emilinate bumpsteer?
can i remove the stabiliser bar thing at the bottom and replace it with another item, if so do i get any more ground clearance ? or any better handling..... theres more to cum when i think of it hehe
oh, and i ha ve play in the steering.... turn it then the wheel turns bout ..... 1/8th of a turn.... probly less... is this steering box?
and brakes, 1-2inch of movement before it works, do i need to bleed or is there another adjustment i need to do?
adz
Could be. Dunno if these early ones have a universal joint thingy like mine. Look in the front and find the box and adjust it up.
If you pump them and they go hard then it is bleeding. If not you may need to asdjust the pads.
HAve a look in Robs site. I will be amazed if he doesnt have a how to for those topics
http://www.geocities.com/MotorCity/Lane/1970/
TTFN
BArry
Adam
This is a 40hp pre 67 car sint it... check and see if there are camber shims fitted behind the lower torsion tube on the bulkhead... these are alloy half moons thingies...
If there not there then go get some and fit them.
Not much you can do with Camber n Castor and there not adjustable in a King n Link
the best thing to do is make sure the torsion arms are straight in the proper VW jig and teh stub axles arnt not bent also using the VW jig.
Are teh King n Ling pins worn n need replacing ??
Brakes are the wheel cylinders new old... are the flex hoses new old
Is the brake pedal push rod adjusted correctly are the brake shoes adjusted correctly. Are the wheel bearings right
These are all little things that contribute to your steering n braking
Adam_C ·
yep 66 1300 model dave...... will check all of the above and see how it goes🙂
Adam_C ·
oh and you too Baz
dave dad will ring you tomorrow about the bits and peices....... sorry for the delay, hectic times at work.... and the alsheimers doesnt help :P
adz
bug eyed ·
Mate
bump steer is one of the things
that makes beetles so much fun
to drive.........
seagull ·
To my buggy a few mods but no problems with it ,good adjustment ect ,lock ,turning great
