Aussieveedubbers 路 Tech Talk
VW fuel injection vs carby\'s
https://forums.aussieveedubbers.com/threads/18799/vw-fuel-injection-vs-carbys
kombi_kid 路
hey
whats the pro's and cons of original VW fual injection on 2L type 4 motors VS the carbies??
rhys
Flintstones 路
with injection is starts first time every time no matter what the condition is, no need to consistantly tune twin carbies.
Plus if you wanted more power later on, you can add a turbo, cause your half way there already with the injection. Just change the computer to a programmable, add bigger injectors, intercooler, and larger fuel pump. (your engine will need to be in good nick to go turbo though)
That'll shock a few people especially when your pulling away from then 馃榾
kombi_kid 路
i plan to go watercooled down the track this is just to get the kombi on the road and have both 2L EFI and 2L carby motor
rhys
mnsKmobi 路
If the FI and the motor it's on are in good condition I'd use it in preference to the carb motor.
kombi_kid 路
does EFI have any prone problems and is the EFI parts expensive??? dont know the condition of the EFI unit or the motor although the motor has good compression
rhys
KruizinKombi 路
I have heard that stock efi motors run lean at revs, but then other people I've spoken to believe that this isn't true. I'm undecided, so you'll have to make your own decision on this.
My efi 2L ran hard with very little maintenance. My biggest problem was sticky injectors, because I kept forgetting to put the Mobil Fuel Injector Cleaner in every third tank like my mechanic told me to. I believe PULP would render the stuff obsolete now though. :thumb
The only other problem I encountered was a blown diode in the control unit, which caused it to run on three cylinders. Trouble is, when my mechanic cleaned one, it moved to the next injector. 馃檨 Took him about 2 hours of removing, cleaning and testing injectors to work out what the problem was!! :jesus
kombi_kid 路
yer
dad reacons not to use the EFI motor cause u can get these sorts of problems!!! but i like the idea of turnin the key starting straight away and not tuning carbs!
rhys
DoNkEy 路
are FI 2l engine rare? I am after a kombi, FI be nice to have but are they common?
kombi_kid 路
abit more common then type 3 EFI's!!!
rhys
seagull 路
holden camera set up works very well Up hills ect no problems
KruizinKombi 路
Rhys, the problem I had was a once off, and considering how little maintenance my 1st kombi got in the 8 years of hard use I gave it, it did extremely well. Not to mention the fact that it was a 76 model that had probably not seen much maintenance prior to me owning it. I would definitely recommend FI over carbies. :thumb
Donkey, FI engines aren't exactly rare; I believe that most 2L '76 models were FI, as were a lot of 1800 '75 models. The problem is that in the 70's, FI was generally misunderstood, so a lot of owners opted to remove the FI setup and revert to carbies. As a result, the FI setup is somewhat uncommon these days, but not exactly sought after either, so relatively cheap.
As seagull indicated, other FI setups can be adapted to the kombi motor quite successfully. The kombi setup only has a 9 stage (from memory) vane-type airflow sensor and is very simplistic (and inefficient) when compared to the systems from later model cars. The danger when using EFI from another vehicle is that other vehicles are not mapped to provide the fuel requirements for a kombi, which is particularly important as the kombi is air-cooled and has more potential to overheat than a watercooled engine. This may not be an issue, but should be checked to make sure and the system chipped or remapped to suit the kombi's requirements.
I personally believe that the better option for those not wishing to use the stock FI setup would be to utilise a programmable aftermarket EFI setup, perhaps with the stock FI manifolds. While this is more costly, a decent aftermarket system will have more load points, and more sensor inputs so it can more efficiently determine the fuel requirements of the engine. A really good system will utilise an EGO (Exhaust Gas Oxygen) sensor to constantly retune itself as you drive. Higher end units will also control ignition timing, and can retard the ignition when the engine gets hot to prevent engine-killing pre-detonation. :thumb
kombi_kid 路
thanks for that colin helps alot!!
rhys
Robo 路
Hi Rhy's
I hope you dont mind me adding to your question (post) Im not trying to hijack it, I just want to know a bit more about it.
I would like to know more about this myself. Everyone seems to drool over twin Dellorto's, but from most mechanics I have spoken too (Not VW mechanics) Fuel injection is a much better option. with the price of dual Dell or Webber carb set ups ($1500-$2500) Fuel injection may be a more cost efective option. What sort of set up costs would be involved in doing this.
