Conrods play
https://forums.aussieveedubbers.com/threads/18860/conrods-play
karmannghia60 ·
I removed the P&C off the 1835 (which I will be converting to 1776 by the way). I grabbed the end on the conrods and moved it from one side to the other. There is about a 1mm play. Is this OK? As far as I know, the free play (!) at the crank end should be between 0.1mm & 0.4mm with 0.7mm being the worn limit. Correct?
Raf
Gracey ·
About 16 thou max from memory, not sure what that is in metric.
Andrew Grace
Doug Sweetman ·
16 thou = 0.4mm
karmannghia60 ·
0.44mm what? At the end of the conrod or at the crank?
Gracey ·
Side clearance between conrod and crankshaft.
Andrew Grace
splitbusaustralia ·
The axial clearance of the conrod on the crank (ie the side-to-side movement) or
'gap' when you push the conrod to one side and measure to the crank should be
0.17 to 0.4 mm 'new' with an outer wear limit of 0.7mm. So is this is what you are referring to yes you are correct!
On the other hand, the movement of the crank in the case is the 'endplay' measurement...
RobK
