Aussieveedubbers 路 Members Rides
CRAIG TORRENS J&S
https://forums.aussieveedubbers.com/threads/19188/craig-torrens-js
Craig Torrens 路
A sorry site at the moment馃檨......................but soon to be a offroad BEAST !!!!
Craig Torrens 路
Working on the side intrusion and integral rollcage/windcreen...........
Craig Torrens 路
Starting to work on the front beam, bracing the shock towers as well as welding the tower joins............ adjusters and rebound/bump stops still to be done!!
baybuscamperkid 路
good to see some serious thoughts to safety going into this project, shows what a high level of thought and planning goes into your projects馃檪
56astro 路
If you want somewhere to store that white beetle in the background of the first pic .....
my garage is free!
馃榾
Craig Torrens 路
馃榾馃榾
you should see what's in my other garage 馃槈 馃榾馃榾
Alex Holzl 路
Wat is it craigie come on tell us come on???
Alex Holzl 路
Hang on hang on, let me guess!!! issss it mmmmmmmmmmmmmm ummmm a circuit racing car by any chance...????馃榾
manxed69 路
Craig,
I like your roll bar work, I can't wait untill it's all finished.
:thumb
Craig Torrens 路
I can't do much until I get my pan from WHM !
The bar work should help stiffen the buggy a lot. The cage will bolt to the pan as per the picture, as well as down to the gearbox forks and the rear torsion housing.
I will get some more pics soon !
manxed69 路
I understand why you want to stiffen your buggy, the twisting that I get is unbelievable. My pan has 25 X 50mm tube up the sides and I don't think that that is enough. I'm planning to weld a 50 X 50mm section on top to help stiffen it which will also raise my body by two inches. I'm not sure if this is the look that I want but with what I do with my buggy I need to stop some of the twisting.
