kombi engine bay stuff?
https://forums.aussieveedubbers.com/threads/19355/kombi-engine-bay-stuff
kombi_kid ·
hey
im stuck with getting out the stuff that is above the engine on the top and stops heat getting through into the cabin????? i will get a pic ASAP to show what i mean! i cant find it anywhere in the manual
rhys
kombi_kid ·
this is the stuff
Robo ·
What do you want to get it out for?
Rob..😎
koolkarmakombi ·
Its held on by Rivets. Look around the frames. use a larde drill bit to drill out the heads or use a dremel
kombi_kid ·
yer i thought that i though they might of been screw in though?!?
i want to take it out cause im painting in there and also im putting in a type 3 engine lid (as its a 72 i has no engine lid )
rhys
p.s. can the rivets be replaced?
Robo ·
That explains it!
I would assume that the rivets would be generic and quite easy to replace.
Rob..😎
Andy ·
Yep, drill old ones out, and replace with new. Easy job.
If you can't find pop rivets with the large heads like original, just use a large washer under a smaller pop rivet :thumb
