Where on earth are the timing marks on a EA 71 - Subaru Motor????
Anyone know????
Moniek
baybuscamperkid ·
timing marks? i have an engine and 2 manuals that i can check in, but not sure what your talking about?
speedster356 ·
If like the EA82 then there should be marks on the outer dia of the flywheel. Does it have a removeable rubber plug on the top of the bell housing?
[Edited on 25-2-2004 by speedster356]
Mrs M ·
Its a EA71 that has been adapted into a Baja it has no plugs on the Bell housing as its using a VW gearbox and modified Vw flywheel.
Has anyone had an experience in finding timing marks
Moniek
11CAB ·
Heheheh.....is it in the car yet??
If it is, you'll have to take out No.1 spark plug, put a screwdriver into the hole and turn the motor until the screwdriver doesnt come out any further indicating TDC, then you'll need a degree wheel and mark off you timing mark.....not sure what it is (somebody else might know).......
Have fun.....
Graham
ibmoknegawsklov ·
yeah its in and kinda running, need to hook up radiator and at the moment i'm modifiying the engine cage to fit around the motor. I kinda was thinking of finding TDC and useing the case split as the line (just like a dak dak motor) If i divide the pulley diameter buy 360 it will give me a measurement / degree. I just need to know what to time it at i guess around 7 degrees before TDC should be close.
[Edited on 25-2-2004 by ibmoknegawsklov]
speedster356 ·
Try here www.ausubaru.com
Have been good for Subaru info in the past.
Mrs M ·
Thanks for the info.... checked it out but hmmmmm think we will have to do it the hard way,,,, lucky i have a switched on husband
