Another hot superbug is soon to hit the streets. Brendans 71 superbug was an absolute throw away the first time I saw it in his garage, but he saw through it all an evisioned a hot German look beetle.
It features fully adjustable struts, 17 inch wheels, custom dash & a 2110 stroker!
All work has been done. by the owner, from welding all the repair panels, painting it in his garage, porting his 044 heads & all the engine assembly!
Gives new meaning to the Phrase "Bult not bought::thumb
It may not be quite ready in time for the Nationals, but fingers crossed dude馃槈
Kai.A. 路
cool :thumb
great colour for getting noticed too....
kai
Jeza 路
Wow
That is both inspiring and immpressive. One talented dude 馃槑
And gives a moral boost - perhaps my project car ain't so bad after all....
Luv to see more as it progresses
Jeremy
wacked1 路
Is it me, or is that colour getting popular. Looking good. :thumb:thumb:thumb
GL1972 路
Thanks for the kind words guys. It has been 18 months to this point! The car was originally going to be Cyan Blue (The color of the fan shroud) but my daughter convinced me to go the green.
The pictures above were after the 3 main color coats and a 800 and 1200 rub back awaiting final coats. I finished the painting yesterday. 1 coat of 40% color and 60% clear. 2 coats of 5% color and 95% clear. How good is it when you peel the masking off!!! Im real pleased with the results. It'll only need a light rub back with 1200 and then a light buff. I'll post some more pics after that. In the mean time if you want to have a look at some other pics and text go to Angry Gumby in the members rides.
Jeremy this site has kept me going! Watching all the other builds and wanting to keep up.
Jak if I don't get it regod intime for the Nats can I borrow your plates馃槈
Lugnuts,
The dizzy is off a 86 magna ($45 from the wreckers plus $40 for the machining). I have also built a Jaycar programmable curve ignition system and high energy module to go with it. I will start the engine with the original dizzy first then "introduce" the new bits once everything else is sorted.
How good is that paint job on David's bug? If mine turns out half as good as that I'll be rapt.
jakriz 路
Yeh Davids car is real nice, what did his 2332cc put out on the dyno???
I'll put my plates on your car Bren if I get to flog it down the 1/4 mile:thumb
Jak
GL1972 路
Jak,
I'm not sure that I like the words "flog it" when referring to the fruits of my labor馃槈
It will be real interesting to see how it pulls down low with that rod ratio.
As far as HP is concerned I'm hoping for mid 90s at the rear wheels with good torque readings. Anything above that is a real bonus.
Boozer 路
that's a very kool colour!馃榾:thumb
66fastback 路
David's 2333 only put out 89hp on the dyno. The heads on the engine are tiny 35mm ports. They are ported but small.
It is currently being reassembled with CB performance 040 CNC ported heads with ratio rockers.
That will wake the baby up.
Those polished fuchs are up for sale. It now has 18 inch turbo twists. Helps see those porsche/brembo brakes really well........
56astro 路
GL1972 wrote:It will be real interesting to see how it pulls down low with that rod ratio.
What is it's rod ratio?
jakriz 路
Its an 82mm crank with 5.4 inch cb rods (5.394 is standard I think) engle 110 cam, standard rockers, 40x35 044's 40mm dells. Should be a great tourqey motor, perfect for a stock geared full weight superbug on the street.:thumb
Jak
56astro 路
jakriz wrote:Its an 82mm crank with 5.4 inch cb rods (5.394 is standard I think) :thumb
Jak
Down around 1.6:1 - 1.7:1 then.
She'll be a snappy one!
:o
GL1972 路
I'll post all the engine specs..
AS41 Case (clearanced by me). 10mm studs and case savers.
Bugpak 82mm crank.
CB H beam 5.4inch race rods.
Mahle 90.5 stroker pistons.
CB 044 40x35.5 heads single HD springs. (I unshrouded the valves, straightend up the intakes a little and opened them up, cleaned and polished the exhaust ports) geez I love that porting tool!
Chromoly pushrods.
Engle 110 cam (the engine was originally going to be a 1916cc)(will be replace with something a bit more special later eg: K8 &1.4:1 rockers).
Lightened flywheel.
All rotating parts balanced.
Full flow oil pump.
Standard oil cooler as well as Mesa style external cooler and external filter.
'86 Magna dizzy with programmable ignition.
I originally started this car to give to my daughter as her first car with a mild engine.
I think I've got a bit carried away in the last 18 months. Maybe I should buy another 1302 for her and keep this one and install a roll cage.
Brendan
:jesus
jakriz 路
roll cage :bounce roll cage :bounce roll cage:thumb
snappy all right Steve, I drove a 2387cc(86x94) with 5.5 inch rods & it was on from idle, no waiting around for the K-8 cam to kik in, it was off from the get go, it had 120@ the wheels with only old unported 041 heads & 8.5:1 compression! It felt as though the engine & gearbox was going to come through the firewall & end up on your lap! Awesome & scary at the same time:thumb
GL1972 路
Oh yes I forgot.
Compression is set at 9.0 : 1
graeme86 路
Ahhh... Cyan Blue..this is what it would have looked like....
Babybug 路
Great work. I hope my beetle will be ready to paint soon, so much welding to do when will it ever end.
Jodie
GL1972 路
The Cyan color does look great! I kept the blue on the tinware and the underbody for a contrast. Looks good now the car is painted and buffed.
I will post pics this weekend once the guards and on with beading.
Jodie, sometimes I thought I'd never finish the welding (2 heater channels, section the floor for new seat mounts, battery tray area, + more than a dozen other panels) I did all the welding old school with the oxy acetylene torch. It took over a year to strip it down and back to the point of finishing the welding.
Don't give up!
Brendan
:jesus
GL1972 路
I'l repost the completed paint pictures. The car now has all 4 guards on and I'm installing the L bug 3.88:1 gearbox. I had to have 2 goes at this since when I changed the front nose cone I did not have all the selector shafts lined correctly.
Brendan
GL1972 路
Another
GL1972 路
Mmmmm glossy
GL1972 路
Can't ait to join all this together. Going to install solid rocker shafts before I do though. I've come all this way with this engine and have standard shafts, hmmmmmm.....nup!
GL1972 路
More
GL1972 路
Gumby
GL1972 路
OK the Gumby was a bit of fun. (Reference to Angry Gumby in Members Rides).
The engine is in!! Oil system is plumbed up. Making ally sheet apron to replace the steel one.
Brendan
:jesus
Cam 路
Mate, thats looking gorgeous. Top job!
GL1972 路
Thanks Cam.
Just had another look at it. The ride height looked great until I rolled it backward and forwards a couple of times. The only problem is it's got nothing in it except for the longblock. Looks like resetting the suspension AGAIN!:cry
It's probably out by 1 inch at the rear axle.
A few weeks ago I made one of those spring plate tensioner tools that bolt to the shock tower and hooks under the plate to let it down gently.
Brendan
Oasis 路
Why don't you weigh what's left of the engine and put the equivalent weight in the back of the car to set the ride height? On the long block even? Just a thought. It will take the guessing away. Looks FANTASTIC by the way!
GL1972 路
Oasis,
That's not a bad idea. I'd have to add the windows, upholstery, battery etc. I might wait till there is more fitted up. Going to take some days off work to get a roll on with it. My weekends seem to be taken up with Surfing and Kids sport.
Brendan
Oasis 路
Cool, or if you can't wait to fit them all, just weigh them all one at a time, and put concrete bags or whatever weights you want in the car at around the right spot so you get the right cantilever effect (i.e. if you put the battery weight behind the rear axle it will weigh the car down more than in its usual spot). One weight in the right spot for rear windows, battery, and back seat, probably placed around where the battery would go, and a weight for gen, pulley etc...resting on top of the long block. I know I'd be hanging to see how the car "sat" if it was mine:thumb
[Edited on 13-4-2004 by Oasis]
GL1972 路
Oasis,
I just looked at your post time. You gotta get some sleep or at least see your doctor about some sleeping pills!:thumb
Back to the bug. I'm pretty patient. I've been on this project since September 2002 and have missed every deadline I have set myself. (I originally told my wife it would only take 3 - 4 months!)
I've going to install new axle rear seals before installing the rebuilt CVs, so I think I'll do the lot together.
Regards
Brendan
:jesus
Oasis 路
Just got up (kidding). :thumb
Cool. What's another week!
GL1972 路
I started the engine for the first time on Friday Night. I'm sure the neighbours enjoyed the sucking sound of two Dellortos to the sound of the Olympics.
Besides a minor problem of the rear oil relief valve sticking (which we caught straight away by monitoring the guage) it went very well. Still running rich but starts and idles now. I'll put some axles in it during the wek and may have a drive up and down the street on the weekend. I'll get some pics and post an update.
It's a relief after building the engine last November. You know how it is, you start to second guess yourself after so long. "did I tighten that bolt right, is that bearing in the right way, was that clearance correct...".
Brendan:jesus
Dasdubber 路
Top work - can't wait to see some more pics!
VWFREAK 路
Top job champ, my hat goes off to you.
waltermitty 路
Mate very nice, shre is a credit to you , what are the wheel/tyre sizes and offsets, any major work to fit them?
I am contemplating 17 " cup wheels or similar in porshe stud pattern.
Mitchell
GL1972 路
Mitchell,
The wheels are Lenso Concept 5s. 17"x 7" ET40. The car has 100mm shortened struts with 80mm 150 pound King Springs. There is about 10 - 15mm clearance from the inside of the tyre to the spring. I also had to set the turn to turn steering lock limits.
Brendan
GL1972 路
Got it out in the sunshine for the first time yesterday. No bonnet or engine lid but you get the idea.
