Alternatives to Wd 40
https://forums.aussieveedubbers.com/threads/19758/alternatives-to-wd-40
nicko 路
Is there any better penetrative products than WD 40? I sprayed WD40 all over my hinge screws and the couple I have got out have no evidence of penetration.
vwtyp2 路
Wurth Rostoff :thumb:thumb:thumb:thumb:thumb
if that doesn't work, it ain't coming off 馃檪
vwtyp2 路
the Brand is Wurth. (German, so you know it must be good)
the product is called Rostoff. (you can work out the translation)
Mad Manx 路
Boltoff- it comes in a blue pressure pack
modulus 路
Don't know if it is still available, but I used to use "Penetrene"... ah those were the days, when 2 bobs' worth of Penetrene lasted a lifetime and got into everything....oops, I've wandered off....
It would not be a bad bet that the active ingredient of WD40 is kerosene, mixed with a few carriers, emulsifiers and spray-mist additives....
hth
MikeM 路
Inox, best stuff for pentrating rust and a whole pile of other uses.
I work for a big australia wide food manufacturing compay and our maintenence department use this stuff extensively.
Inox is Aussie made and exported to the world.
http://www.ppc.au.com/category98_1.htm
http://www.aussieweld.com.au/product_pages/inox/inox.htm
You can buy it from most bulk bolt suppliers, I know these guys stock it:
BOLTS & INDUSTRIAL SUPPLIES PTY LTD
145 Evans Rd Salisbury 4107
(07) 3277 6944
or
7 Pritchard Rd Virginia 4014
(07) 3865 6944
It comes in spray can, bottled or tinned. The un-pressurized stuff works great out of a universal spray pump likr the cheap ones you get from the supermarket.
If WD40 doesn't do it give Inox a go. You'll never use WD40 again. :thumb
[Edited on 3-3-2004 by MikeM]
Now that I think about it I've also seen INOX at super cheap auto. But it's cheaper from an Industrial supply house.
fetid_swamp 路
inox is mintox :thumb
smells good too
HotRodMatt 路
Penetrene is still made by Chemsearch. Good stuff.
11CAB 路
Wurth Rostoff is the go....also has a lovely orange smell to it
robnjo 路
....gas axe and a hammer...very smooth LOL
El Duderino 路
Plus gas works a treat, dunno if its available over there?
Chris
waltermitty 路
rustoff
kombikim 路
Wurth Rostoff is by far the best
Inox & Penetrene or Penetrol are the best generally available
Inox is the best multi purpose & doesn't hurt rubber/ neoprene etc like WD40 will
Wurth is not easy to get but most people in the trade use it
tonyg 路
Put plenty inox or penetrene on... leave it sit a while. Put a large correctly sized screw driver in, one with the metal part right thru the head, give it a solid whack with a bigger than your average chippies hammer. If that does not loosen it, get a manual type impact driver, give it a whack with that. If that does not work, get a butane torch or oxy and heat the visible bit up as much as poss, then repeat the wacking bit.
if none of the above are successful, take a 20 litre drum of unleaded, pour carefully (you don't want to get splashed, it will ruin your complexion) thru the interior. Then take your local trading post paper and a trusty bic lighter, apply in the logical order, and presto, no more worries about frozen nuts or screws or whatever.
heheheh
nicko 路
Thanks for all the advice.
Cheers Nicko
Baja Wes 路
Just thought I would add inox has a website
http://www.inox-mx3.com
It is Australian made stuff, you can buy it almost anywhere. Repco, autobarn, supercheap.... There is a big list of suppliers on their website.
barls 路
px 24 or ardrox is the best stuff for rust penetration dont know who its made by but its the stuff. this stuff is wd bigger heavy hitting brother
Craig Torrens 路
ZX4567 gettyoffa, made in Botswanna by little people...............great stuff.
oval TOFU 路
maybe try spraying it from the other direction (from iunderneath?) I had to do that with my G'box nose cone which was pretty much dirt-welded together. After a few days of spraying from one side and not having much effect, i sprayed from the other and in about 24 hours... all is good!
seagull 路
Inox is the go , good for ally work , taping holes , and getting bolts out .
amazer 路
Go to summernats, go to INOX guy, tell him you're a fitter and you dont use inox, get free cans of inox :thumb
amazer 路
Laugh till it hurts when your painter mate cant get any :P
