hey people
this is all happening to our type 3 1500 motor.
it struggles to idle and when giving it a boot full in 4th and slowning down u get a big bang and then when it gets hot it struggles to even go!!
its running the twin 1500 carbies which have been rebuilt.
any help ????
rhys
Old Dubber ·
Sounds like lean mixture.
Look for vacuum leaks.
mnsKmobi ·
Is the timing right?
kombikim ·
I agree with MNS Kombi
this is usually a timing /distributor guts issue, the carbies are the last thing that should be touched unless something is visually obvious
Robo ·
Dont know much about Type 3's but in a Kombi there is a balance tube between the carbs, sometimes the rubber elbow's come off the pipe creating a vacumm leak, the symtoms are the same as you mentioned. might be worth a look if there is a similar balance tube in your car it could be the problem.
Rob..😎
robnjo ·
sounds like dissy,if you havn't, why not put a NEW 009 in it ,their cheap enough.
kombi_kid ·
it has a 009 in it we will put the original back in!!!
we have blocked off the balance tubes should we unblock then and stick in the balance tube??
rhys
70AutoStik ·
That might help a heck of a lot! Without the balance tube the poor little 34picts will be suffering badly from the reversion pulses.
karmannghia60 ·
Could it be a bad tension lead?
kombi_kid ·
fiddled around with the leads and it has become alot better!!! it is know not idling and backfiring have got rid of it running like a dog!!!
rhys
