Aussieveedubbers 路 Tech Talk
Hi rev miss
https://forums.aussieveedubbers.com/threads/19949/hi-rev-miss
AdrianH 路
Ive been chasing it for a while, any suggestions would be appreciated.
On the ignition side Im running a 009 disi with compufire, mallory coil and a hyfire VIal (same as MSD 6al). Plug wires are new, wiring is good, runs fine till about 500 rpm short of the limiter (7000) then develops a miss - If I keep pushing the rev limiter cuts in.
On the fuel side, electric pump, holley reg, dellortos. I had a tank vacuum problem that I fixed (no vent on tank ). I thought maybe it was a pump problem and leaning out.
I thought I might be floating valves, springs are bugpack duals, and only have 900 miles on them. I am going to change them anyway just in case.
Any ideas ???
lugnuts 路
How big are the valves dude 馃槈
AdrianH 路
42 inlet 37.5 exhaust
Peter Leonard 路
the sound of valve float is pretty definate...
sure it's still making power at 7000? take it to a dyno and add the figures to the dyno gang bang 馃槈
AdrianH 路
You are right its not valve float, Im going to play around with jets. I kind of have to beat it up to stay in the groove with my gearbox.
3.88:1 r and p and stock ratios, it takes a bit of convincing to get to the top of third...
If there was a dyno worth going to within 100 miles of here Id be there.
[Edited on 8-3-2004 by AdrianH]
modulus 路
It's kind of hard for us to guess where 'here' is since you haven't filled out your location. Ettamogah? Turkistan? Mongolia?
hth
Peter Leonard 路
5 to one one Uzbekhistanislovenia 馃榾
lugnuts 路
Kiwi :thumb
AdrianH 路
Good guess - Kiwi small rural town, bunch of V8 guys locally, gave them a bit of a scare at the local car clubs 1/4 mile sprints (in the pouring rain) ran a 15.57 with no traction in first, yet to get to a real strip.
