anyways, Danielles car ATM has a 009 dizzy in it (apparently) and while rummaging thru the spare parts,
I found what is obviously the old dizzy, which is a vac advance only unit.
and then, on a stroll thru the wreckers, we stumbled upon a dizzy with both mechanical and vacuum advance units on it. (SVDA I think you guys call them)
the dual advance dizzy needs some bits put on to get it working, but is possible.
so now to the real question, what is the best dizzy, power and driveability wise, to use on the car, vacuum only (stock) mechanical only (009) or vac and mech advance.
I am a mechanic myself, and from what I can tell, it would be worth fixing the dual advance dizzy and using that, as it offers, or should have, a better ignition curve referenced from both engine RPM and engine load/vacuum.
BiX 路
your going to open a can of worms with this one. But tell everybody first what type of vehicle and what engine specs you have. Normally i would go for a stock engine, either the vacum or dual. and a 009 for a performance engine.
Rota_Motor 路
thanks people, I guess I was on the right track after all 馃檪
I figured just about every other car maker had both advances for a good reason, I just wasnt sure if there was a reason to only use one advance.
and a good reason doesnt include 'because there is more to go wrong'
I guess this means I will be rebuilding the wrecker dizzy when I can be bothered.
lulu94 路
Ryan forgot to tell you that its for a beetle.
We dont know what the engine specs are as we dont know what engine we have
Danielle:P
Bizarre 路
The SVDA is the best
009's are only good for duals so u dont have to worry about a vacuum signal
