Type 3 trike will not start
https://forums.aussieveedubbers.com/threads/20249/type-3-trike-will-not-start
Beetle bailey ·
When I turn the key the starter turns over ok & lights work but the engine does not fire? Any suggestions as to the problem? She has been running a little rough & not sounding her usual self
Well it could be one of 2 things
Fuel or spark Check the easiest one first which is fuel pump the accelarator and look down the carby is there fuel pumping down the throat ???
KruizinKombi ·
Hey Beetle bailey, do you know if the Bros MC still has a clubhouse in Yarraville? My ex-boss was the club secretary going back about 15 years. 🙂
Check the fuel as Dave suggested, then check that you have spark at the points. If you have, try checking the timing next. :thumb
Beetle bailey ·
Thanks for the help, Looks like I know what I will be doing this weekend
Beetle
Check Your Rotor Button inside the distributor. VW rotors have a resistor imbedded in them between the inner & outer contacts.... if there is a burn mark there, the resistor has burnt out....
A burnt out Condensor will also stop an engine. Make sure the points are opening. If the condensor is crook, Your points will be pitted or burnt, a points file will help here, for a tempory fix until new points & condensor are installed. A Points file is a Great tool.. I wouldn't be without one... They can start many a stopped engine & keep it running...
Jenny ·
If you don't have a "points file" you can use a finger nail file. The diamond coated ones work best. Just make sure you clean it before you give it back! 🙂
Peter Leonard ·
points files are kinda like stuffing boxes instead of tap washers. with the contacts on points these days, just get a new set. seriously. criminy. I mean really. what's the world coming to. 😀
