BUGGA... Old Box 2bolt mount @front, NEW box 4bolt mount... What Am I to Do..
https://forums.aussieveedubbers.com/threads/20319/bugga-old-box-2bolt-mount-at-front-new-box-4bolt-mount-what-am-i-to-do
Marineboy ·
Well Here is a Small issue...
As U Will tell I am a little New to Buggy-ing.. But learning fast with a Box Swap in Progress..
However the 4spd Swingaxle I Just got from the Wreckers has a 4 Bolt Front Mount.. ???
This should be a 1500 box (I Have to go on the Wreckers word on that, any way I can tell..? Box Number or somthing)
My Manx's Toasted Box has a 2 Bolt front mount...
Also the Rubber shock mount is different and the plate after the shock mount (What would I imagine bolts to the Chassis) will not fit in just looking at it...
My chassis has a Flat plate with a square Rubber block (Both Vertical) and that bolts onto the Box with 2 bolts...
So What do I do...
Can I Swap the Front cone part of the box around...?
Should I Go back to the Wreckers and ask for a Different box, if so What one has this 2bolt mount at the front...?
As you can imajine I am soooo keen to get out there and play with this new Buggy of mine... I hope someone out there can help me...
Get back to Buggy-ing..
Thanks in Advance....
Marineboy...:cussing
Menangler ·
Just swap the nose cone and it will be fine,
The new box you have sounds like a later model 1300 box (if it is a swinger), it will have a different throw out bearing set up and also a lower 4.375 ring and pinion, your old 1500 box had a 4.125, so it will rev a bit more on the freeway, but will zip through the gears faster!.
Marineboy ·
Excelent....
BUT... is there a way to tell from the outside of the box if it came off a 1500 or a smaller engine size..
My Manx has a Subaru 1.8L, so I would rather the Taller Ratio's to drive on the Freeway without the poor little Subie screeming her heads off...
I will Trawl through my Manual and see if I can see any info in there..
Thanks for all your help...
Marineboy
