hey guys, I think I posted this before, but it may have been lost?
anyways, what stud pattern is our beetle?
4/1970, 1500, with disc brake front and the narrow 4 stud (not wide 5)
thanks in advance?
Jeza ·
4 stud as you know and 130 pcd (pitch circle diameter).
Only thing similar is the 914, ie 2l fuchs.
I had thought that as an easy solution you could try using 924 drums and rotors as they are essentially the same (would give you 4 x 108- I think- same as peugeot), but probably the easiest thing to do is just buy blanks and get them drilled to what ever pattern you want- then fit the wheels you desire.... Unless you desire empi 8 spokes or similar or globes etc
Jeremy
Peter Leonard ·
I'm currently doing the wheels thing myself. it seems possible that it may just work out cheaper to get custom wheels made to suit the PCD. but then I'm after 16" x 7" and 61/2". or something. not a lot of wheels out there that'll fit that bill with a 130 PCD.
Rota_Motor ·
thanks guys, I did wrote a heap more, but it got lost :cussing
now I need to find a spare wheel, thats all I needed the info for 🙂
