hi there,
i wanted to change my tail pipe as they are in bad shape....i've unbolted the backets connecting to the muffler...and tried to pull them out to replace them by my new ones...but ...nothing...馃檨
anyone got any idea on how i can handle this?
[Edited on 25-3-2004 by sleeper]
lugnuts 路
Multigrips or a stilsen or vice-grip pliars but never having done any of the above im only guessing :P
vw139 路
you could try heating the joints a little, tapping with hammer then tug with all your might!
BiX 路
Bit of wd 40, then a stilsen will do the trick and if they are really stuck, use and angel grinder and have to get a new muffler
sleeper 路
mmmm....
i did put some wd 40...but didn't seem to work....
bix, what is a stilsen?
i try again tonight....
think i may have to visit a muffler place...
or get a new muffler !!!!馃檨
BiX 路
Stilsen, like a monkey wrench, those big ones you see the stero typical plumber carrying around. Just give it a little time to work, thry them when they are hot to.
sleeper 路
hi bix....
will do...thanks for the advise...馃檪
eirecooled 路
Hi having same battle with my'61. have one out (heat ,cold chisel bloody big vice) had to remove the whole muffler to get some more elbow room.
Good-luck
VolksFolks 路
Try Some Elbow Grease $2.95 K-mart
Andy
lol
empi man 路
Using an angle grinder cut along the bottom of the muffler where the tail pipes slide in,prise open the cut and squirt in some WD type of stuff!Using multis or vicegrips,twist the tail pipes.It your 're careful,you'll be able to re-use the existing muffler.Have fun!
ph billet 路
I had the other problem thay kept slipping off had to pop rivit them on!!!!
sleeper 路
well....about to start the pipe battle soon...
will post the results馃槈
Grey 57 路
Be careful with the early 36 hp mufflers. They are getting real hard to find now and exy when you do. Bettter to twist the old tail pipes off even if they break then carefully dig the bits that are left in out. Possible to run a hack saw blade down inside the bit of the tail pipe thats left in there to release it.
sleeper 路
I WON !!!!!!!!!!!!!!!!!!!!!
after a long battle of WD40 spraying...heating....twisting....bending the pipes....spraying WD40 .....hurting my knuckles...bleeding to death from cuts...more twisting...THE PIPES ARE OUT !!!!!!!!!
anyway after 45 min....馃榾
now i got my new pipes on and my cheese grater:thumb:thumb:thumb....one mission down and getting ready for the next one....
vwombat 路
Dude, you're just like Frodo! Against all odds, and with no small deal of personal pain. You rock!
