Aussieveedubbers 路 Tech Talk
blow by box how to do ?
https://forums.aussieveedubbers.com/threads/20741/blow-by-box-how-to-do
seagull 路
I see some of the bigger motors have these fitted how does this box work and does any one have one they dont need ? thanks seagull
lugnuts 路
Well according to god breather boxes are to separate the oil from the air/oil mist thats in your case and to let your case breathe by venting via lines to your carbs and to then return the oil to the case on deceleration,and i have no idea what i just said so direct all enquiries directly to GOD.馃檪
seagull 路
:jesus
Brad 路
They basically act as an air filter for your case / tappet covers and reduce crank case presure thus reducing blow by. I use a K & N filter on top of a funnel. This allow breathing when under pressure and when not it just runs back into the case.
You can buy breather boxes for like $50 which are alloy case filled with foam .
Brad 路
oops forgot to say I am not god, the above is just my opinion :party
seagull 路
a new or s/hand unit ( or I will swap for a fuel filter like the one I am sending you )
BiX 路
you can make your own. Got one welded up at an exhaust shop, bought the fittings I needed and then the hose out it all together. Box cost $30 to make up plus hose plus fittings
MikeM 路
seagull wrote:a new or s/hand unit ( or I will swap for a fuel filter like the one I am sending you )
http://www.mickmotors.com.au
Mickmotors have a kit, about $60 or so. I bought it for my engine and it has all fittings etc. I would replace the hose that comes with the kit but the good hose is about $3 from a hose supplier.
Brad 路
I have one of these in the shed, it is what Mike is talking about.
You have U2U :>
Oh the stuff in the pic is the kit BUT the Alloy Filler cap is not part of that, these are sold on their own.
[Edited on 29-3-2004 by Buggy Brad]
kombikim 路
I thought the blowby box was designed to fill engine bay & cabin with a fine blue haze & asphixiating fumes:jesus oh well, back to the drawing board
