Well, I thought I had figured the problem out, but evidently I either got it wrong or replaced a faulty part with an identical faulty part.
Every now and then, usually only once per drive, but almost with 100% regularity after getting fuel (after a few minutes), my poor old blue bus suddenly slows down. It feels like the driver just stepped off the accelerator completely and suddenly, when he/she did no such thing. The engine runs extremely rough and kombi has very little energy - she can't get above 40 usually, on the flat!
I normally 'fix' the problem by shutting the engine off. After a moment start it up again. Sometimes this fixes it straight away, other times I repeat the procedure several times. After that she's great again.
Now a volksy mech in Springvale (VIC) told me that it was likely the cut-off valve on one carby. This seemed reasonable - during playing up, two cylinders weren't working, but _were_ sparking. So those two weren't getting fuel thanks to the silly cut-off-valve cutting off. Seemed reasonable, although why they put such a valve on, I can't imagine - and only on one carby? Why oh why?
Anyway, I thought I knew which one (valve) the mech was talking about - on the carby, there are three electrical leads, and he meant the one closest to the front of the car right? Right?!! Well, I found another 1800 motor, and pillaged that little valve from it's carby, and put it on mine. "That'll fix her. How do you feel now old girl?"
Evidently she didn't feel better. :-( Yesterday after getting fuel (BP Premium of course), she did the same as she always does after getting fuel: couple of minutes OK, then splutter-splutter-sloww..... And I only got 3litres, as the fuel stopped coming out after that - apparently they'd run out (ooh, hope I didn't get a whole lot of bottom-of-the-barrel crud).
Well, if someone could tell me I'm incompetent, that I changed the wrong thing, I'd be grateful; or, if you've heard of similar problems, then too.
Oh man, well, she's always fun to drive, that's for sure.
Aurel.
aggri1 ·
