Aussieveedubbers 路 Tech Talk
Magfire installation
https://forums.aussieveedubbers.com/threads/21122/magfire-installation
franko 路
hi all, i just bought a magfire kit for point replacement but didnt get any instructions.looks pretty simple, red to coil pos, black to coil neg,?disk with magnets over dissy shaft and then rotor back on?condensor into tool box with points for justin?set ignition timing with strobe like usual?is this right? any info appreciated.
fatboy 路
Make sure the sensor is seated properly before the disk goes on !
I nearly had a disaster 馃檪 yeah time with a strobe as static timing with these kits will cause big hassles
mnsKmobi 路
I haven't got a magfire, I've got a Pertronix but I imagine they're fairly similar. An important bit you left out was setting the gap between the sensor and the magnetic bit. The Pertronixs kit supplied a thin plastic feeler gauge to set the gap.
franko 路
thanks mns .hmmmmmmmm, the magnetic disk looks like its not adjustable,it just goes as far onto the shaft as it can.anyone know if the magfire needs to set somehow like the Petronix?
Bizarre 路
no - you just slide it on as far as it goes
franko 路
thanks blue,away i go!!!!!
