1600 Beetle Engine Removal
https://forums.aussieveedubbers.com/threads/21511/1600-beetle-engine-removal
count ·
"Removal" searches come up with everything BUT Engine Removal:cry
As well as what is in the Workshop Manual,
are there any other tips for the removal of the motor
from a 1974 1600 Beetle?
How do I tell if it's a Generator or an Alternator?
Ivan
Generator the body is the one diameter.
Near the pulley is holes on either side and you can see the commutator and brushes. Ususally 2 studs on top for wires.
Alternator it is fatter at the pulley end, and solid case - no holes. Alt also has a 3 pin plug and a 8mm stud for wire attatchment.
Che Castro ·
try google groups
http://groups.google.com.au/groups?hl=en&lr=&ie=UTF-8&oe=UTF-8&q=engine+removal&btnG=Search&meta=group%3Drec.autos.makers.vw.aircooled
engine removal is pretty easy once you've done it a few times. Make sure you have a good floor jack and jackstands, and take your time to do things perfectly.
[Edited on 12-4-2004 by Che Castro]
read here
http://www.geocities.com/vwresource/engine_removal.html
save this site
heaps of good stuff there
