Lowering a 54 beetle
https://forums.aussieveedubbers.com/threads/21754/lowering-a-54-beetle
byronbus ·
What are peoples thoughts on dropped spindles or adjustable front beam?
I need to change the link/king pins on my oval anyway and trying to decide which way to go...thoughts?
sleeper ·
hi bruce.....
feel the need of being in the weed?????well done....i got adjustable beam on mine and lowered it to the max since you last saw it and put some 135 at the front.....only 8 cm from the road now......:thumb:thumb
bugboymatt ·
Both ! Adjustable front beam just incase your not happy with the drop of the spindles !
Might aswell get a norrowed beam while your doing it !!
byronbus ·
Thanks matt,
I dont want it in the weeds, keeping it totally stock, just want to sit a bit lower...I feel ill being so high in the air
Robo ·
Hey Im watching you!
Rob...😎
bugboymatt ·
spindles will give you same ride quality but lower as now with standard shocks and such like. will increase your track alittle tho.
Adjusters, lower you go ride changes, fillings can shake loose from your teath on these quality roads here in OZ ! Can be quite harsh. if you go low need different shocks, castor shims and a couple more items to get back some characteristics.
lugnuts ·
What ^ said 😉
byronbus ·
Dropped spindles are alot cheaper and easy as i have to do the link and king pins anyway...
byronbus ·
Rob, will remain original, just a little lower stance, something to make her feell a little younger...
Drop spindles are available in Sydney if you need them, proberly easier and quicker to fit. do you want new King n ?Lings as well ??
cumonghia ·
take out the spare and put a bag of cement in there. cheaper than 600 bucks for drop spindles. Just kidding but that would work wouldnt it?
byronbus ·
Spoke to mike at Custom Bugs and Buses, he talked me into adjusters on the front, cheaper than dropped spindles and easier to fit as he'll give me an exchange beam and he'll make up the king and link pins so that i can fit them straight on...works out cheaper and i can raise it if need be.
Give CBB a 5 star rating, used them lots and Mike always has the time for advice...
Twoguns, the twincabs starting to look a winner!!!
