I have a type3 1600 with twin standard 32PDSIT carbs.
I have put carb kits through and cleaned both carbs.
I have replaced the fuel lines and fuel filter
I have replaced the flexible hoses on the equalisation/balance pipes (this had two not the one)
Prior to carrying this out engine ran rough but would idle all but a little higher than normal
the problem now is the engine won't idle and only runs whilst revving.
If you hold the throttle at half it will die unless you keep revving it.
Have tried to set up as per manual instructions but this is
difficult because it won't idle.
I'm going to play some more this arvo but if anyone has any ideas it would be appreciated.
It appears both carbs may be doing the same thing.
I don't believe I have any air leaks but will look further.
Stanley ·
