ive put my thoughts into it and im going to upgrade the bug!
im thinking an 1835 engine, twin webers, disk brakes for the back and replacing wiring to start.
can anyone give me a ball-park figure on how much the engine setup is going to set me back? id like to get an idea on how much i should be paying before i start ringing around.
much thanks in advance! :thumb
[Edited on 22-4-2004 by Starbuggy]
karmannghia60 路
My 2c worth
Forget 1835, you are wasting your time and money. They have thin cylinder walls so they warp quickly and are notorius for blow-up. Stick to 1776 or 1916.
I bought my 1776 P&C for $540. Heads were $520 (all new). Used mild cam $70. Heavy duty 30mm oil pump $75. Dual 40mm DRLA $650 including linkage. Manifolds were $100. There is a guy on eBay.com.au (in Qld I think) selling rear disk brake kits for $700
You better call the bank manager 馃檪
Bizarre 路
I am sitting here at work so i will say a few things
The motor will cost UP TO $8000 for a drive in drive out Pobjoy special.
You can get away for around 1/2 that
This all depends how much you are going to do yourself.
If nothing i would budget for the $8k cause otherwise you need a crash course on carb jetting and the like.
That said you may find a going bug with a nice motor for that sort of money and do a motor swap with yours and get out of it for a grand!!
Brahes will cost you another grand.
To do it yourself YOUR way is the dear way - especially if you dont do the work.
It would be cheaper to find a bug already done
Che Castro 路
yes avoid the 1835, the cylinders are too thin and weak.
budget at least $4000 for a 1916 or 1776. You might even be happy with just a 1600 with some dual carbs and a cam. which would be a lot cheaper
Starbug 路
thanks muchly for the info guys! i'll avoid 1835's at all costs now!
i'll do some ringing around for a 1600 or 1776 and compare prices. I dont mind doing as much of the work myself as i can (gotta learn something you know!) and have a while to undertake it so im not too fussed.
do micks sell 1776's? or shall i enquire elsewhere?
BiX 路
try some other places to. I got a very nice street motor from "Leons motors" down on the south side. That was using my hold heads, case, crank and reworked rods etc. He built the engine head to head and then I did all the tine ware and stuff. I also fully stripped the motor for him to save time. I think it cost about 4ish winlcuding carbs, But it depends on ur choices.
Starbug 路
thanks BiX! i'll give them a call too!馃榾
Peter Leonard 路
go the 1916!!:bounce
Remember, you'll be driving it a long time, might as well make it fun 馃榾 save and go all the way, at least you'll know what you're getting.
Maybe call Stan 66543694, he'll give you a clear idea of what you're getting yourself into 馃榾
bigbruvabob 路
whwn i, decided to go pobjoy stan was willing to do a base1916 in kit form for me for about 5700, but cant remeber if this included carbies . all machining and preassembly done you just put together.
