I have a case starting with a F my book tells me this is a very good case ,is there others ??:alien
Che Castro ·
The F case is a 1300 case i think. The best case for a type 1 build is a late dual relief case. They are the ones with 8mm head studs with factory case savers, 8mm studs for the oil pump and other studs. They have larger oil passages.
toplessbug ·
i rekon if you are gunna chuck a heap of money at go fast bits do yourself a favour and get a new case with all the mods already done at least you dont have to worry about that bit of it,,, old cases are stuffed,,, even if you dont contemplate a hotty it is still worth the investment as it will last not like flogged out old line bored cases.
Che Castro ·
Yeah i second that. a new AS41 Dual Relief case is the best choice. It is made out of an alloy with higher aluminuim content than the older cases.
Unless its only a cheap throw together, the price of new cases these days is pretty affordable because of the AUD. A good used virgin case wouldn't be that much cheaper anyway. Dont support a few thousand worth of parts on an old case.
jnr356 ·
article on this subject in latest vw australia magazine with stan pobjoy.
seagull ·
yes just got my ( loan ) copy to read .
kombi_kid ·
hey
when building my bro's 1916 it took stan 6 cases to finally get the right one to work on!
go the new alloy cases!
rhys
seagull ·
me fitting ej20 turbo due to cost of vw donk !
waltermitty ·
How much are the new alloy cases?
Mitchell
depends if you buy here or if you ship in yourself.
They retail here for about $1000......I think !
A lot cheaper if you bring in yourself.
yeah, I secon dthe 'new case with thousands of dollar engine' theory. I have had three cases in 10 years - never again. My new 1916 will be built on a new alloy case - I'll probably have it forever
Che Castro ·
the alloy cases are about the same price as AS41's on www.aircooled.net actually they're cheaper if you dont get them with warranty . $300 USD
