I have built a transistorized High Energy ignition Kit for My Beetle.. I haven't installed it as yet...
The cheaper kits You Buy - use the same points & distributor You are using now, but instead of 12 volts to the coil, they usually put Hundreds of Volts.
My kit puts 312 Volts into a standard coil.. I had to take My Bosch GT40 coil OUT as they can over heat... A Standard coil is used... You only set the points in these when the rubbing block on the points wear down..
The actual points never get burnt etc... and if the system breaks down... You just disconnect it and reconnect the condenser and away You go again.... If You have the Expensive 'No Points" system & it happens to break down, You are stuck.. It may never break down...
From all reports, ALL these systems give out a Larger spark than normal.. and Your Points Don't burn.. ever !!!
Petronix is one... Can't remember the other one...
Your Engine should start better & immediately if not sooner!!
IMHO - You should add a relay to Your starting system..
actually VW should have added one in the 60s....
I'll tell You about it tomorrow...
Lee --
http://au.msnusers.com/My1968restoredBeetle/shoebox.msnw?
[Edited on 4-5-2004 by 68AutoBug]
