Just thinking, what would happen if you plugged your fan shroud outlets (the ones that go to your heater boxes) into the intake - it was sealed up airtight 馃檪
Do you think this would work as a crude form of supercharging 馃檪
Just a silly idea 馃檪 I'm guessing the intake might rob the engine fan of needed air???
ideas :P
vw54 路
You would have to fit J pipes as no air through the heater boxes will cause yr engine to over heat.
I think there would be too much air capacity for the engine, and its not really compressing the air only pushing it.
Che Castro 路
hmmm I never turn on my heaterboxes in summer, and I dont have problems. dont the late heaterboxes still pump air through the heaterboxes but have a valve open which lets the hot air out in the lower engine bay?
Anyway my suspicion was that it would not have enough pressure... although the fan does pressurise the air when it hits the fins. Is anyone game enough to try it and see 馃榾 ?
AdrianH 路
yep, its a silly idea... although if youve got nothing better to do, you may as well give it a crack.
Adam_C 路
has been done..... i have an old mag here of a yelow beetle, opera windows choptop air con big stereo and a thingo rigged up like that...... ill search for it and stick a copy up .... or emil you jon
